Would you please advise me the proper library/ source code to use with?
I am using PIC16F877A with GLCD 128x64, S6B0108 controller.
I tried to use library HDM64GS12.c but it did not work properly.
I also upload the result after use HDM64GS12.c; here is link
Thank you in advance.
Regards
Prakasit
dyeatman
Posted: Sat Jun 07, 2014 1:56 pm
Have you searched the forum for S6B0108 and KS0108B?
There is a lot of entries on this forum for the KS0108 and
four for the S6B0108.
I originally used HDM64GS12.c on the DsPIC and it worked for me with no
problems, so apparently you have issues that must be fixed. It will take
some work on your part.
As I said earlier I have used HDM64GS12.c However, to add functionality I
downloaded and converted the DIGOLE library to use the
PIC133FJ256MC710, so there are other options out
there if you want to put in some time and effort. _________________ Google and Forum Search are some of your best tools!!!!
