CMatic
Why does OLED need RAM in the PIC Microcontroller? |
Posted: Sun Jun 01, 2014 11:16 pm |
I am new to OLED .96" Display and while reading this forum, I can not clearly understand why the OLED display need to use the RAM in the uC? And why writing directly pixel by pixel functions are bad? Thnx |
Posted: Mon Jun 02, 2014 12:02 am |
You are asking questions about some PIC software driver for your OLED
display. But we don't have your driver file.
1. Post a link to the OLED driver file.
2. Post the manufacturer and part number of your OLED display. |
Posted: Mon Jun 02, 2014 12:22 am |
As a comment, ignoring the lack of detail for a moment, the graphic LCD driver may well give a clue.
On this there are two ways of using the driver. The first only uses a little RAM, and setting/clearing a pixel, involves sending the commands to read a byte where the pixel 'lives', then setting/clearing the pixel in this byte, and writing this back. Slow.
Then there is a second mode, where the PIC holds a copy of 'what is to be displayed', and setting/clearing a pixel is done by setting/clearing it in the 'copy', and then writing the copy to the display.
I'd suspect your OLED, is being driven in this second manner.
Some do not offer the ability to read, and so can only be driven this way. These would have to have the whole display held in the PIC RAM.
Some are super smart, and give high level commands to draw lines etc., and require almost no PIC RAM.
Some can be driven either way but at a cost in speed.
So as PCM_programmer says 'details'. |
CMatic
Posted: Mon Jun 02, 2014 2:49 pm |
PCM programmer wrote: | You are asking questions about some PIC software driver for your OLED
Thank you PCM Programmer for your reply. I will try to clarify my question. I have bought the 0.96" OLED with SSD1306 controller chip. I have searched the forum but after reading all the OLED comments, I was wondering why the Pic16F88 chip was a poor choice for driving this OLED display as it has RAM 368 bytes but the OLED display needs about 1K of RAM. But I don't understand exactly why this is bad? |
CMatic
Posted: Mon Jun 02, 2014 2:58 pm |
Ttelmah wrote: | As a comment, ignoring the lack of detail for a moment, the graphic LCD driver may well give a clue.
Thank you Ttelmah. I have a OLED 0.96" with SSD1306 controller. My question was regarding the second way, so when the uC completes an I/O operation to the OLED it is much slower then reading uC RAM and writing to the external OLED Display. |
Jerson
Joined: 31 Jul 2009 Posts: 125 Location: Bombay, India
Posted: Mon Jun 02, 2014 11:26 pm |
You say that a particular chip is bad in conjunction with OLED 0.96" I have used such a display in the recent past.
1 - You will need quite a bit of ROM space to hold all the fonts you wish to use.
2 - If you need to do lots of random image type operations, it will be better to use a shadow memory in RAM to get a good frame update rate(FPS). The SSD1306 has its own buffer to refresh the LCD and in most cases can be used as the shadow memory. However, using the SSD memory is much more slower than using a page buffer right on your micro controller.
If you are going to use the OLED mainly for displaying fonts and a few line graphics, the amount of RAM on the chip may not be very important. You will need much more ROM for any amount of decent graphics.
Usually a chip with ROM capacities of >32kb is suggested for graphic type lcd operations simply because you cannot work with just one font. You may need a couple of fonts at least; one small size, one big size. |
Posted: Tue Jun 03, 2014 12:24 am |
Also, the speed in talking to the chip, will depend on the interface being used.
The fastest 'low number of pins' interface, is the four wire SPI interface. Use this with the hardware SPI on the PIC, and a byte can be sent in just a couple of PIC instruction times. The I2C is slower, but again uses a nice low pin count.
Key problem is that the smaller interfaces (I2C/SPI), have the following comment in the data sheet:
"No data read is provided in serial mode operation."
This explains why the RAM in the PIC is needed.....
If you switch to one of the parallel interfaces, then data read is supported, but then twelve pins are needed on the PIC to control the interface.
So assuming the driver you have uses SPI or I2C, then the answer to your original question is in the data sheet. |
CMatic
Posted: Tue Jun 03, 2014 1:11 pm |
Jerson wrote: | You say that a particular chip is bad in conjunction with OLED 0.96" I have used such a display in the recent past.
Thank you Jerson. Now it makes a lot more sense to me why we need more ROM. |
CMatic
Posted: Tue Jun 03, 2014 1:13 pm |
Ttelmah wrote: | Also, the speed in talking to the chip, will depend on the interface being used.
Sir you hit it right on the head! Its in the data sheet, No data read is Serial mode operation. Thanks very much. |
