neochrome32
dsPIC33EP256Mu806 PWM or DAC how |
Posted: Sun Jun 01, 2014 6:52 pm |
CCS C 4.130
i went through the wizard: and it created something, but doesn't compile
now the thing is, i cant for the life or me work out the code to setup TWO PWM outputs!??
33EP256Mu806
#include <main.h>
#PIN_SELECT OC1 = PIN_F0
setup_compare(1,COMPARE_PWM | COMPARE_TIMER2 );
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_1,0 );
setup_spi( FALSE );
setup_spi2( FALSE );
//setup_dac(DAC_RIGHT_ON, 5);
setup_timer1(TMR_DISABLED|TMR_DIV_BY_1);
for(;;){
output_high(E1);
output_Low(E1);
bit of a fail for compiling :(
its a really really basic code, just to being the Hello-world function...
not working :( |
dyeatman
Posted: Sun Jun 01, 2014 8:55 pm |
Where are the contents of main.h?
We need to see all the code if you cant get it to compile so we can test it _________________ Google and Forum Search are some of your best tools!!!! |
Posted: Mon Jun 02, 2014 6:34 am |
Depending on what frequency you want (using 0 for the timer will give you a very low frequency), you need something like:
#pin_select OC1=PIN_F0
#pin_select OC2=PIN_F1
setup_timer2(TMR_INTERNAL | TMR_DIV_BY_1, 500);
setup_compare(1, COMPARE_PWM_EDGE | COMPARE_TIMER2);
set_pwm_duty(1, 250L);
setup_compare(2, COMPARE_PWM_EDGE | COMPARE_TIMER2);
set_pwm_duty(2, 250L);
If you want different frequencies, then use a second timer.
Dyeatman's comment is exactly right. The general rule is that what you post should be compilable, or what you are trying to compile. Otherwise we have no hope of knowing what the problem is.
Your compiler is rather early for the chip, so there might well be problems with some functions. |
neochrome32
Thank you |
Posted: Tue Jun 03, 2014 7:06 am |
Is that ALL you need to do??
a pin select??
OHHHH setup_compare(1, compare_pwm_edge)...... im used to see
OHHHH setup_compare(1, compare_pwm | .....)...... im used to see
Whoohoo.. thought i bought a bunch of chips that couldn't cope with it (concerned as dsPIC depicts a Digital audio out stuff! hehe)
Thank you Ttelmah |
