CCS intel HEX CRC calculation
ncubed
PostPosted: Tue May 27, 2014 3:57 am     Reply with quote
CCS PICC creates an Intel HEX file, with the last line containing a 16-bit CRC code.
Presumably, this is a CCITT-16 code of the file.
Does anyone know if all characters are passed through the CRC register or binary data translated from the HEX?
Any help would be appreciated.
Best regards
Noam
PostPosted: Tue May 27, 2014 5:15 am     Reply with quote
The checksum is a simple sum of the bytes in Flash memory and the Configuration bytes, i.e. it is not a CRC.
In the past there have been troubles with this checksum changing between compiler versions. Because documentation on this topic is poor it is difficult to say which variation is wrong or bad. Perhaps you are better of to write your own checksum calculation routine, then at least you know what is tested and you control the algorithm changes.
Here is an old 2003 discussion on the topic with an algorithm by Darren Rook (a CCS guy) that should give you a head start.
http://www.ccsinfo.com/forum/viewtopic.php?t=17536
In a 2012 thread another algorithm was presented but I don't trust this one as it is a CRC16 algorithm and not a simple summation:http://www.ccsinfo.com/forum/viewtopic.php?p=163228
bkamen
PostPosted: Tue May 27, 2014 10:43 am     Reply with quote
You could always read up on the Intel Hex format...
http://en.wikipedia.org/wiki/Intel_HEX
It's CLEARLY explained there...
PostPosted: Wed May 28, 2014 2:00 am     Reply with quote
As I understand it, the TS is asking about the checksum in the last line of the hex file. This is a line in comments and not part of a standard Intel Hex file so reading up on the Intel Hex format will not help to explain this CCS generated checksum.
bkamen
PostPosted: Wed May 28, 2014 8:48 am     Reply with quote
as I re-read the post -- and your comment -- I realized what he (and you) are talking about.
As already ID'd, that's NOT part of the Intel Hex format.
Sorry - my bad....
