Setting INT_IO2 for 16F88
Tharon Hall
PostPosted: Tue Oct 21, 2003 5:40 pm     Reply with quote
Question So how do I set the config bits for the oscillator to INT_IO2 on a 16F88 when it is not one of the #fuses??? Question
PostPosted: Tue Oct 21, 2003 6:07 pm     Reply with quote
I believe you should use this fuse option:
INTRC_IO
It sets the Fosc bits to: 100
The 16F88 data sheet describes this option as:
100 = INTRC oscillator; Port I/O function on both
RA6/OSC2/CLKO pin and RA7/OSC1/CLKI pin
PostPosted: Wed Oct 22, 2003 6:25 am     Reply with quote
INTRC_IO
Page 35 that discusses the various modes calls this mode "INTIO2". The #fuses comments in 16F88.h do not define "INTIO2", "INT_IO2" nor "INTRC_IO". "INTRC_IO" is what I use for the 16F819.
If it works, it wouldn't be the first time that a fuse setting wasn't in the .h file. grrr.....
PostPosted: Thu Oct 23, 2003 1:18 pm     Reply with quote
INTRC_IO
Mad Nope. It did not take "INTRC_IO".
I get "unknown keyword in fuses". Mad
PostPosted: Thu Oct 23, 2003 1:25 pm     Reply with quote
This is for the 16F88 ?
What is your version of the compiler ?
DaveThib
PostPosted: Fri Oct 28, 2005 7:15 am     Reply with quote
I am using a PIC16F87 and I also want to use RA6 & RA7 as input pins and have been having trouble getting it to work. It is not well documented in the data sheet as well. So I tried setting the fuse INTRC_IO and it worked!!! So thanks a lot for the info! One of the symptoms I had is that the SPI quit working as well. I had everything working using other pins and I needed to make changes and all I changed was those two pins. After my change those pins did not work and the SPI quit sending data.
Thanks again for the help!
