Problems with PWM output 4 on PIC16F1827 pin RA4
AJEllisuk
PostPosted: Sun May 25, 2014 1:55 am     Reply with quote
I'm working on a project to generate PWM output 4 on RA4.
The problem I have is that when I turn off PWM4 with:
set_pwm4_duty(0);
setup_ccp4(CCP_OFF);
RA4 stays high, I've tried forcing it low with
output_low(PIN_A4);
But that does nothing. How do I setup PWM4 so that it sets the output low when the PWM is inactive?
Kind regards
Andrew
PostPosted: Sun May 25, 2014 2:55 am     Reply with quote
Turning the CCP 'off' disables the peripheral. So the duty cycle no longer applies. Remember the duty cycle needs to be a 'long'. So simply:
set_pwm4_duty(0L);
should set the output low.
The 'priority' on this pin, is:
SR latch, PWM, T0CKI, C2OUT, RA4
So when you disable the PWM, unless T0 is set to use an internal clock, and comparator two is disabled, these will both have priority 'over' the simple pin function, stopping it from working.....
AJEllisuk
PostPosted: Sun May 25, 2014 3:39 pm     Reply with quote
Hi Ttelmah
Thank you for your reply; my problem is now resolved.
Kind regards
Andrew
