inverting pixel in ccs
haemtenem
PostPosted: Mon May 19, 2014 4:51 am     Reply with quote
hi, i want to show my data on GLCD with pic16F series.
I use ccs compiler.
I want to make my output be similar to following picture that i attach, pixels are inverted.
Can anyone help me?
thanks
http://8pic.ir/images/73332841988849275670.png
PostPosted: Tue May 20, 2014 4:17 am     Reply with quote
Depends totally on your display, colours available, and the driver being used.
However normally, you would call a drawing function to draw a rectangle covering the area required, with the pen set to 'set' the pixels, and then draw the text with the pen set to clear the pixels.
PostPosted: Tue May 20, 2014 5:09 am     Reply with quote
As Mr. T says depends on the LCD module.
Some will have a 'reverse character' or 'inverse' option. Every video card for every PC has had that since '77!
Be sure to download the datasheet of any LCD module you might purchase and see if it's an option.it might cost a few pennies more but it will be faster/easier to code than the pic doing it.
hth
jay
