gjs_rsdi
rs232 problem - SOLVED |
Posted: Tue Apr 22, 2014 12:35 am |
I am sending from the PIC 19 bytes that should be:
55h,AAh,16*00h,FFh
I get:
19*00h
The message is sent once a second. (enable_interrupts(INT_TBE);)
Tested with two different terminals, both same.
The program was working fine and suddenly stopped working. I made this test program to try to find out what is the problem.
Testing in MPLAB simulator, no problem.
I am using basic FTDI USB to TTL converter
CCS PCM C Compiler, Version 3.249, 37061
Help much appreciated.
#include <16F648A.h>
#FUSES WDT
#FUSES EC_IO
#FUSES BROWNOUT,MCLR,NOLVP,NOPROTECT,NOCPD,PUT
#use delay(clock=8000000,RESTART_WDT)
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,restart_wdt)
#int_TBE
void TBE_isr(void)
restart_wdt();
switch(scomtxwords)
case 0:
putc(0x55);
scomtxwchs=0x55;
scomtxwords++;
case 1:
putc(0xAA);
scomtxwchs=0xFF;
scomtxwords++;
case 2:
putc(0x00);
scomtxwords++;
case 3:
putc(0x00);
scomtxwords++;
case 4:
putc(0x00);
scomtxwords++;
case 5:
putc(0x00);
scomtxwords++;
case 6:
putc(0x00);
scomtxwords++;
case 7:
putc(0x00);
scomtxwords++;
case 8:
putc(0x00);
scomtxwords++;
case 9:
putc(0x00);
scomtxwords++;
case 10:
putc(0x00);
scomtxwords++;
case 11:
putc(0x00);
scomtxwords++;
case 12:
putc(0x00);
scomtxwords++;
case 13:
putc(0x00);
scomtxwords++;
case 14:
putc(0x00);
scomtxwords++;
case 15:
putc(0x00);
scomtxwords++;
case 16:
putc(0x00);
scomtxwords++;
case 17:
putc(0x00);
scomtxwords++;
case 18:
putc(scomtxwchs);
scomtxwords=0;
disable_interrupts(INT_TBE);
gjs_rsdi
Posted: Sat Apr 26, 2014 3:47 am |
I have rewritten the software, same problem
#include "Scom1.h"
#include <math.h>
#include "Scom1VR.h"
#include "Scom1SC.h"
#int_TIMER0
void TIMER0_isr(void)
restart_wdt();
timecounter++;
if(timecounter>=60)
timecounter=0;
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256);
setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
setup_vref(FALSE);
enable_interrupts(INT_RDA);
setup_oscillator(False);
restart_wdt();
Scom1.h
#FUSES WDT //Watch Dog Timer
#FUSES EC_IO
#FUSES PUT,NOPROTECT,BROWNOUT,MCLR,NOLVP,NOCPD
Scom1VR.h
//serial communication tx variables------------------------
int scomtxwords=0;//scom tx switch
int scomtxwchs=0;//lsb of the check sum
//serial communication rx variables------------------------
int timecounter=0;
short scomfailflag=0;
short newsetdataflag=0;
short readdataflag=0;
short devicereadwriteflag=0;
int scomrxwords=0;//scom rx switch
int scomrxw0=0;//0x55 sinchronization byte0
int scomrxw1=0;//0xAA sinchronization byte1
int scomrxw2=0;
int scomrxw3=0;
int scomrxw4=0;
int scomrxw5=0;
int scomrxw6=0;
int scomrxw7=0;
int scomrxw8=0;
int scomrxw9=0;
int scomrxw10=0;
int scomrxw12=0;//received check sum
int scomrxwchs=0;//calculated check sum lsb
Scom1SC.h
//SCOM TX
#int_TBE
void TBE_isr(void)
restart_wdt();
switch(scomtxwords)
case 0:
putc(0x55);
scomtxwchs=0x55;
scomtxwords++;
case 1:
putc(0xAA);
scomtxwchs=0xFF;
scomtxwords++;
case 2:
putc(0x00);
scomtxwords++;
case 3:
putc(0x00);
scomtxwords++;
case 4:
putc(0x00);
scomtxwords++;
case 5:
putc(0x00);
scomtxwords++;
case 6:
putc(0x00);
scomtxwords++;
case 7:
putc(0x00);
scomtxwords++;
case 8:
putc(0x00);
scomtxwords++;
case 9:
putc(0x00);
scomtxwords++;
case 10:
putc(0x00);
scomtxwords++;
case 11:
putc(0x00);
scomtxwords++;
case 12:
putc(0x00);
scomtxwords++;
case 13:
putc(0x00);
scomtxwords++;
case 14:
putc(0x00);
scomtxwords++;
case 15:
putc(0x00);
scomtxwords++;
case 16:
putc(0x00);
scomtxwords++;
case 17:
putc(0x00);
scomtxwords++;
case 18:
putc(scomtxwchs);
scomtxwords=0;
//SCOM RX
#int_RDA
void RDA_isr(void)
restart_wdt();
switch(scomrxwords)
case 0:
scomrxw0=getc();
if (scomrxw0==85)
scomrxwchs=85;
scomrxwords=1;
scomrxwords=0;
case 1:
scomrxw1=getc();
if (scomrxw1==170)
scomrxwchs=255;
scomrxwords++;
scomrxwords=0;
case 2:
scomrxw2=getc();
scomrxwchs=scomrxwchs+scomrxw2;
scomrxwords++;
case 3:
scomrxw3=getc();
scomrxwchs=scomrxwchs+scomrxw3;
scomrxwords++;
case 4:
scomrxw4=getc();
scomrxwchs=scomrxwchs+scomrxw4;
scomrxwords++;
case 5:
scomrxw5=getc();
scomrxwchs=scomrxwchs+scomrxw5;
scomrxwords++;
case 6:
scomrxw6=getc();
scomrxwchs=scomrxwchs+scomrxw6;
scomrxwords++;
case 7:
scomrxw7=getc();
scomrxwchs=scomrxwchs+scomrxw7;
scomrxwords++;
case 8:
scomrxw8=getc();
scomrxwchs=scomrxwchs+scomrxw8;
scomrxwords++;
case 9:
scomrxw9=getc();
scomrxwchs=scomrxwchs+scomrxw9;
scomrxwords++;
case 10:
scomrxw10=getc();
scomrxwchs=scomrxwchs+scomrxw10;
scomrxwords++;
case 11:
devicereadwriteflag=getc();
scomrxwchs=scomrxwchs+devicereadwriteflag;
scomrxwords++;
case 12:
scomrxw12=getc();
if (scomrxwchs==scomrxw12)
scomfailflag=0;
if(devicereadwriteflag==0)//if '0', device read command
// readdataflag=1;
else//if '1', device write command
// newsetdataflag=1;
// scomfailflag=1;
scomrxwords=0;
// enable_interrupts(INT_TBE);
Mike Walne
Posted: Sat Apr 26, 2014 7:02 am |
I have not got a snowball in Hades chance of solving your problem.
If you want help we need short, complete, compilable code to copy. paste and test.
Your code is none of the above.
a) It's too long,
b) We don't have your Scom1.h etc.
c) No main()
Explains why you have had no response to your original post.
Mike |
gjs_rsdi
Posted: Sat Apr 26, 2014 10:34 pm |
Thanks for the attention Mike.
I shortened the program and put all the headers on the same page as the .c
I am sending now just 5 bytes.
It is compiling, working in the MPLAB simulator, working with the board, but I get: 00,00,00,00,00
instead of 55,AA,00,00,FF
//Scom1.h-----------------------------
#FUSES EC_IO
//Scom1VR---------------------------------
int timecounter=0;
//Scom1SC------------------------------
#int_TBE
void TBE_isr(void)
restart_wdt();
switch(scomtxwords)
case 0:
putc(0x55);
scomtxwchs=0x55;
scomtxwords++;
case 1:
putc(0xAA);
scomtxwchs=0xFF;
scomtxwords++;
case 2:
putc(0x00);
scomtxwords++;
case 3:
putc(0x00);
scomtxwords++;
case 4:
putc(scomtxwchs);
scomtxwords=0;
#int_TIMER0
restart_wdt();
timecounter++;
if(timecounter>=60)
timecounter=0;
//Scom1.c------------------------------
setup_vref(FALSE);
disable_interrupts(INT_TIMER1);
restart_wdt();
Hope it is enough clear and short.
Joe |
alan
Posted: Sat Apr 26, 2014 11:45 pm |
You disable INT_TBE and enable INT_RDA, but you have the interrupt pointing to INT_TBE
Regards |
gjs_rsdi
Posted: Sun Apr 27, 2014 12:19 am |
Hi Alan
I am enabling INT_TBE ones in 2 seconds using timer0 and disable it in case 4 of the switch.
My mistake. I disable the INT_RDA but it is the same.
I am getting every 2 seconds 00,00,00,00,00
Joe |
Posted: Sun Apr 27, 2014 12:30 am |
I also have to point out that on the original code, cases 2, to 17 were all the same code. As such separate code is not needed for these. When I originally saw this, I stopped looking....
On the new example, the enable_interrupts(GLOBAL), does not want to be in the loop. setup_oscillator(FALSE)!. What is this going to do?. See below.
The approach of sending a message using INT_TBE, is perfectly sensible and acceptable, but the actual writing of it is really bad. Do you really have an external clock oscillator module?. If not, the code is not going to run properly. Old comment about is you are using the hardware UART, you _must_ have ERRORS in the #use RS232. Your use of the WDT, is pointless/appalling. The key thing with a watchdog, is it only does some good, if you write the code so that the watchdog is only reset, if the chip is running correctly. Scattering 'restart' instructions round the code, means that it'll get restarted, even if the code is doing unexpected things. In which case you might as well not have the watchdog at all. Waste of code space and time.
The old key thing with debugging, is KISS. Step back, and get rid of all the interrupts, and printf a message. Do you get anything?. Anything other than '0'?. You may well have a simple hardware problem that started the code not working.
If you are going to use the watchdog, specify a divisor for it (assuming that things like this will 'default' to what you want is always dangerous). Then write the code so the watchdog _only_ gets reset if the code _is_ running properly. Get rid of all but one restart_wdt, and make sure that the code sequence _will_ reach this if the code is working, and can't if it isn't.
Your setup_oscillator(FALSE); line, may well be the problem. FALSE codes as '0', and setup_oscillator(0) will switch to about 40Khz operation....
If you say you are getting something every 2 seconds, then either his is the result of a watchdog triggering, or your oscillator is not 8MHz. Timer1, with an /8 prescaler will divide the master oscillator by 4*8*65536 = 2097152. With a counter running 0 to 60 (61 counts), you would get the interrupt being enabled every 16 seconds if your master clock was 4Mhz....
Your chip is not running at the speed you think. |
gjs_rsdi
Posted: Sun Apr 27, 2014 1:42 am |
Ttelmah, thanks for the input.
I changed the program according to your advice (I hope I didn't missed something) except the timer0.
I have an 8Mhz external clock oscillator to free A6 for I/O.
I checked in the simulator, I got timer0 interrupt every 32.768ms, with the counter I am enabling the TBE approximately every 2 seconds.
While compiling, I am getting worning: Variable never used: rs232_errors.
The corected program:
#FUSES EC_IO
#use delay(clock=8000000)
#use rs232(baud=9600,parity=N,xmit=PIN_B2,rcv=PIN_B1,bits=8,ERRORS)
int timecounter=0;
#int_TBE
void TBE_isr(void)
switch(scomtxwords)
case 0:
putc(0x55);
scomtxwchs=0x55;
scomtxwords++;
case 1:
putc(0xAA);
scomtxwchs=0xFF;
scomtxwords++;
case 2:
putc(0x00);
scomtxwords++;
case 3:
putc(0x00);
scomtxwords++;
case 4:
putc(scomtxwchs);
scomtxwords=0;
#int_TIMER0
timecounter++;
if(timecounter>=60)
timecounter=0;
setup_vref(FALSE);
disable_interrupts(INT_RDA);
// setup_oscillator(False);
restart_wdt();
I am still getting 00,00,00,00,00
Joe |
gjs_rsdi
Posted: Sun Apr 27, 2014 2:12 am |
Finishes testing with an other board that have a 8Mhz crystal, changed the fuse to HS but I am getting the same result.
Joe |
Mike Walne
Posted: Sun Apr 27, 2014 2:32 am |
Please confirm the following:-
1) Simple LED flasher works at the correct speed.
2) Simple "Hello World" code also operates OK.
Mike |
gjs_rsdi
Posted: Sun Apr 27, 2014 3:08 am |
I reprogrammed the software that was working before with this board.
The hardware includes an AC motor that works at 5 different speeds controlled by PWM, keyboard with 4 buttons and 5 LED's that are blinking in certain situations.
All buttons functions are correct.
LED's blinking or not, correct for the specific situations.
Motor turns in the 5 correct speeds.
Serial communication does not work. It was working before with the same software.
Joe |
gjs_rsdi
Posted: Sun Apr 27, 2014 3:31 am |
I added the LED per Mike advice to flash every second (500ms on/500ms off) and it works correct.
I didn't change the serial communication as I can read just binary on my terminals. I also don't know how to write "Hello World"
Still read 00,00,00,00,00 instead of 55,AA,00,00,FF
every 2 led flahings.
Still get: Warning 202:Variable never used: rs232_errors
Joe
#FUSES HS
#define ledonoffout PIN_A3
int timecounter=0;
#int_TBE
void TBE_isr(void)
switch(scomtxwords)
case 0:
putc(0x55);
scomtxwchs=0x55;
scomtxwords++;
case 1:
putc(0xAA);
scomtxwchs=0xFF;
scomtxwords++;
case 2:
putc(0x00);
scomtxwords++;
case 3:
putc(0x00);
scomtxwords++;
case 4:
putc(scomtxwchs);
scomtxwords=0;
#int_TIMER0
timecounter++;
if((timecounter==15)||(timecounter==45))
output_high(ledonoffout);
if((timecounter==30)||(timecounter==60))
output_low(ledonoffout);
if(timecounter>=60)
timecounter=0;
setup_vref(FALSE);
restart_wdt();
Posted: Sun Apr 27, 2014 3:51 am |
You still have not done the basic 'hello world' test without interrupts. As I said:
"Step back, and get rid of all the interrupts, and printf a message."
You will get the rs232_errors warning. This was a stupidity by CCS, where when you add 'ERRORS' as part of the error handling code they add this variable, and if you don't use it they give this warning. Understand it is a _warning_ not an error. You can either just ignore it (what 90% of people do), or add single line to access the variable (which stops the warning), or even a dummy function to access the variable, that is never called (which stops the warning, and since it is never called, costs nothing in code...), or just tell the compiler to ignore this warning.
The simulator tells you nothing. It'll believe what you tell it about the clock, which can be wrong. You should not get an interrupt at 32768mSec, with an 8MHz clock, and T1_INTERNAL|T1_DIV_BY_8. The T1 prescaler is fed off Fosc/4. T1 counts to 65536. With an /8 prescaler the interrupt should be at 1/4 the rate you are seeing in the simulator.
Look at the timer1 block diagram in the data sheet. Note Fosc/4 when the internal source is selected. If you are seeing an interrupt at the rate you say, then it tells us something is wrong (oscillator is 32Mhz, not 8MHz, etc..). |
gjs_rsdi
Posted: Sun Apr 27, 2014 4:05 am |
I am not using timer1. Using timer0.
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_256); with 8Mhz is giving interrupt at 32.768ms.
The LED is on for 500ms and of for 500ms with the last program.
Tested with the watch for 60 seconds.
I don't know how to printf "hello world".
I will try to learn.
Joe |
Mike Walne
Posted: Sun Apr 27, 2014 10:47 am |
Main() code fragment something like this should send "Hello World" to a PC at ~1 second intervals.
Code: | void main()
while (1)
printf ("Hello World \n\r");
Your PC needs something like hyperterminal set for the same baud rate as the PIC.
I don't have your PIC, so can't do a hardware test.
Mike |
