thanvuongv
| Send Latitude and Longitude by module sim908 (FTP server). |
Posted: Sat Apr 26, 2014 4:47 am |
I want to code for send GPS signal by FTP server. But code it doesn't run.
Help me!!
Code here is send GPS data to web and send sms(GPS, temperature by DHT11) to phone when have a messenger.
#include <18F4620.h>
#include <string.h>
#INCLUDE <stdlib.h>
#include <ctype.h>
#use rs232(baud=57600, parity=N, xmit=PIN_C6, rcv=PIN_C7, stream=GPS ) // Jumpers: 8 to 11, 7 to 12
void erase_buffer(void); // erase character in buffer[]
void init_sim900(void); // Function to boot sim900
void read_sms(); // read sms message
void send_sms(); // send sms message
void call(); // call to number phone`
void at(void); // test sim900
void sleep_mode(void); // set mode sleep for sim900g1gi
short wait_ok (void); // Funtion to wait string "OK" from SIM900
short wait_error (void); // Funtion to wait string "ERROR" from SIM900
#use fast_IO(B)
#define DHT11_pin PIN_A0
#define buffer_size 160 //Buffer size you can adjust this size
char buffer[buffer_size]; // SAVE SMS MESSAGE
int xbuff=0x00; //
char c=0x00; // the first characters recived of SMS message
char c1=0x00; // the end characters recived of SMS message
char c2=0x00;
short sms_mode=false; // //It's a flag when is true, call read_sms();
char latitude[15];
char longitude[15];
char chua[20];
char chun[20];
unsigned char values[5];
#int_RDA
RDA_isr()
// if(c=='\n'){c1=c; xbuff=0;}
//if(c=='\r' && c1=='\n');
c=getc();
if(c=='#'|| c=='\n'){
c1=c; //first character of phone number
xbuff=0;
if (c=='.' && c1=='#') // the end character OR the first character
sms_mode=true;
else if(c=='\r' && c1=='\n');
if (xbuff >= buffer_size)
{xbuff=0;}
else{ buffer[xbuff++]=c;} // save character of SMS message
return 0;
//************************** erase character in buffer[]***********************
short wait_2D (void){
char *ptr,*ptr1;
char r1_ok[]="2D Fix";
char r1_ok1[]="3D Fix";
ptr1=strstr(buffer,r1_ok1);
ptr=strstr(buffer,r1_ok);
if(strncmp(ptr,r1_ok,6)==0){
return true;
else if(strncmp(ptr1,r1_ok1,6)==0 )
return true;
else{
return false;
erase_buffer();
//------------------------compare with +FTPPUT:1,1, -------------------------------------------
short wait_FTPPUT1 (void){
char *ptr;
char r1_ok[]="+FTPPUT:1,1,";
if(strncmp(ptr,r1_ok,11)==0){
return true;
else{
return false;
erase_buffer();
short wait_FTPPUT1_1 (void){
char *ptr;
char r1_ok[]="+FTPPUT:1,6";
if(strncmp(ptr,r1_ok,10)==0){
return true;
else{
return false;
erase_buffer();
short wait_FTPPUT11 (void){
char *ptr;
char r1_ok[]="+FTPPUT:1,64";
if(strncmp(ptr,r1_ok,12)==0){
return true;
else{
return false;
erase_buffer();
short wait_FTPPUT2 (void){
char *ptr;
char r1_ok[]="+FTPPUT:2,";
if(strncmp(ptr,r1_ok,9)==0){
return true;
else{
return false;
erase_buffer();
//--------------------------------compare with +FTPPUT:1,0 -----------------------------
short wait_FTPPUTOK(void){
char *ptr;
char r1_ok[]="+FTPPUT:1,0";
return true;
else{
return false;
erase_buffer();
//--------------------------wait signal gps ready-------------------------------------------------
void wait_gps(void){
do
printf("AT+CGPSSTATUS?\r");
while((wait_2D() == false));
//------------------------------GPS initial---------------------------------------------
void GPS_init(void)
do
printf("ATZ\r");
delay_ms(2000);
while(wait_ok()==false);
do
printf("AT+IPR=57600\r");
delay_ms(2000);
do
printf("AT+CGPSPWR=1\r");
delay_ms(2000);
do
printf("AT+CGPSRST=1\r");
delay_ms(2000);
//------------------------FTP initial--------------------------------------------------
void ftp_init(void)
do
printf("AT+SAPBR=3,1,\"Contype\",\"GPRS\"\r");
delay_ms(2000);
do
printf("AT+SAPBR=3,1,\"APN\",\"v-internet\"\r");
delay_ms(2000);
do
printf("AT+SAPBR=3,1,\"USER\",\"\"\r");
delay_ms(2000);
do
printf("AT+SAPBR=3,1,\"PWD\",\"\"\r");
delay_ms(2000);
do
printf("AT+SAPBR=1,1\r");
delay_ms(2000);
do
printf("AT+FTPCID=1\r");
delay_ms(2000);
do
printf("AT+FTPSERV=\"ftp.freevnn.com\"\r");
delay_ms(2000);
do
printf("AT+FTPPORT=21\r");
delay_ms(2000);
do
printf("AT+FTPUN=\"freev_14414390\"\r");
delay_ms(2000);
do
printf("AT+FTPPW=\"12345678\"\r");
delay_ms(2000);
do
printf("AT+FTPPUTNAME=\"gps1.txt\"\r");
delay_ms(2000);
do
printf("AT+FTPPUTPATH=\"/htdocs/\"\r");
delay_ms(2000);
//--------------------------------------get gps signal and split to get latitude,longitude----------------------------
void toado()
char term[3];
char don[3];
char xuongdong[3];
erase_buffer();
printf("AT+CGPSINF=32\r");
strcpy(term,",");
strcpy(don,".");
strcpy(xuongdong,"\r");
strtok(buffer, term);
strcpy(chua,strtok(0, term)); // Gets longitude
strcpy(latitude,strtok(0, term)); // Gets latitude
strcpy(chun,strtok(0, term));
strcpy(longitude,strtok(0, term));
//----------------------------------------send latitude,longitude to FTP server----------------------------
void sendweb()
int i=0;
c:
do
printf("AT+FTPPUT=1\r\n");
do
// i=i+1;
//if(wait_FTPPUT1_1()==false)
//goto c;
// else if(i==20)
// goto c;
// else
delay_ms(2000);
while(wait_FTPPUT1()==false);
do
printf("AT+FTPPUT=2,%d\r",strlen(latitude)+strlen(longitude)+1);
while(wait_FTPPUT2()==false);
do
printf("%s,%s",latitude,longitude);
do
printf("AT+FTPPUT=2,0\r");
do
while(wait_FTPPUTOK()==false);
void DHT11_init();
unsigned char get_byte();
unsigned char get_data();
void DHT11_init()
output_float(DHT11_pin);
unsigned char s = 0;
unsigned char value = 0;
for(s = 0; s < 8; s += 1)
value <<= 1;
while(!input(DHT11_pin));
delay_us(30);
if(input(DHT11_pin))
value |= 1;
while(input(DHT11_pin));
return value;
void setup()
disable_interrupts(global);
port_B_pullups(FALSE);
setup_timer_0(T0_internal | T0_8_bit);
set_timer0(0);
DHT11_init();
int get_data()
short chk = 0;
unsigned char check_sum = 0;
output_high(DHT11_pin);
output_low(DHT11_pin);
delay_ms(18);
delay_us(26);
chk = input(DHT11_pin);
if(chk)
return 0;
delay_us(80);
if(!chk)
return 0;
delay_us(80);
for(s = 0; s <= 4; s += 1)
values[s] = get_byte();
for(s = 0; s < 4; s += 1)
check_sum += values[s];
if(check_sum != values[4])
return 0;
return 1;
//**************************** Interrupt USART **********************************
int i;
for(i=0;i<buffer_size;i++){ buffer[i]=0x00; }
xbuff=0x00;
c=0x00;
c1=0x00;
sms_mode=false;
return;
//************************ Function to boot sim900 *****************************
void init_sim900(void){
do
printf("AT\r");//Selecciono la mem sim para recibir y leer sms
do
printf("ATE0\r");//Selecciono la mem sim para recibir y leer sms
do
printf("AT+CPMS=\"SM\",\"SM\"\r");//Selecciono la mem sim para recibir y leer sms
do
printf("AT+CNMI=2,2,0,0,0\r");//los sms se envían directamente al puerto serie
do
printf("AT+CMGF=1\r"); //Habita el modo texto de los sms
void send_sms1()
unsigned char state = 0;
state = get_data();
printf("AT+CMGS="); // at command to send sms
putc(34); // "
printf("01678119857");//xxxxxxxx is your cellphone number
putc(34); // "
putc(13); // CR
printf("Toa do: %s,%s \n",latitude,longitude);
if(state)
printf( "Nhiet do: %3u.%03u \n", values[2], values[3]);
printf("Do am: %3u.%03u \n ", values[0], values[1]);
putc(26);// ctrl + Z
delay_ms(2000);
void send_sms(int n)
state = get_data();
putc(34); // "
putc(34); // "
putc(13); // CR
if(state)
switch(n){
case 1: { printf( "Nhiet do: %3u.%03u \n", values[2], values[3]); break;}
case 2: {printf("Do am: %3u.%03u \n ", values[0], values[1]); break;}
default: break;
delay_ms(2000);
//*************************read_sms()*******************************************
void read_sms()
char *ptr;
char r2_on[]="Nhietdo";
char r3_off[]="Doam";
ptr=strstr(buffer,r2_on); //search string "On" in buffer[]
if(strncmp(ptr,r2_on,7)==0)
send_sms(1);
ptr=strstr(buffer,r3_off); //search string "Off" in buffer[]
if(strncmp(ptr,r3_off,4)==0) // compare result with string "Off". if it is true then function return is 0 and else is 1
send_sms(2);
//************************************send_sms() *******************************
//**************************Function to call*****************************************
void call()
at(); //test at command before call
do
printf("ATD");
printf("xxxxxxxx");//xxxxxxxx is your cellphone number
printf(";");
putc(13); // CR
delay_ms(2000);
while (wait_ok()==false);
return;
void sleep_mode(void){
do
printf("AT+CSCLK=2");
putc(13);
return;
void at(void)
do //SENT COMMAND "AT" TEST MODULE SIM900
printf("AT");
putc(13);
return;
//***************Funtion to wait string "OK" from SIM900****************************
short wait_ok (void){
char *ptr;
char r1_ok[]="OK";
if(strncmp(ptr,r1_ok,2)==0){
return true;
else{
return false;
erase_buffer();
//******************Funtion to wait string "OK" from SIM900**************************
short wait_error (void){
char *ptr;
char r1_ok[]="ERROR";
if(strncmp(ptr,r1_ok,5)==0){
return true;
else{
return false;
erase_buffer();
// Programa principal
void main(void){
setup();
enable_interrupts(INT_RDA);
init_sim900();
GPS_init();
ftp_init();
if(sms_mode==true)//si sms_mode=true se pasa a la función lee_sms()
send_sms1();
//read_sms();
//erase_buffer();
sms_mode==false;
goto a;
a:
wait_gps();
toado();
sendweb();
Posted: Sat Apr 26, 2014 5:51 am |
basic help....
1) does the PIC run the classic '1 Hz LED program'?
2) does the PIC run the 'Hello PC' program'?
3) does the GPS work with a PC ?
4) what interface does the GPS have ?
5) add 'errors' to the use rs232(...options..)?
6) send 'messages to PC ' for EVERY GPS communication
7) most GPS units are usually 3 volt, your PIC is 5 volt !!
8) delay_ms(xx) CANNOT be greater than 65535 !!
9) 'it doesn't run' is NOT helpful. You need to breakdown the program into sections that do. Send messages to a PC or local LCD module to confirm an action has been done(true or false).Use a PC the way your PIC program is coded..does THAT work ?
10) you need to use 'streams' for serial communications. Set one up for 'GPS' UART, the other for the 'SERVER'. Right now ALL communications go to the UART on C6-C7.
recode/recompile/retest/report back
always happy to help
jay |
thanvuongv
Posted: Sat Apr 26, 2014 6:10 am |
thank for your help.
I connected to my PC and test ok. GPS and FTP server is running follow mind.
So. I have all AT-command to connect module sim908. |
thanvuongv
Posted: Sat Apr 26, 2014 6:14 am |
| delay_ms(xxx) less than 65535. But when I send a AT-command is AT+FTPPUT=1. The firsly is "OK" receive and after about 7second is receive +FTPPUT:1,1,1200. So I use delay_ms more than 65535. Can you help me the error. |
thanvuongv
Posted: Sat Apr 26, 2014 6:18 am |
I connected pic18f4620 with PC and when I send a command from pic to module sim908 is receive. Not error.
I use only one UART because I can use AT-command to get GPS signal. |
Posted: Sat Apr 26, 2014 9:01 am |
hmmm...
1)
#use rs232(baud=56000, parity=N, xmit=PIN_C6, rcv=PIN_C7)
baudrate looks 'wrong' to me, maybe should be 57600 ??
2) always add 'errors' to the use rs232(...options....). This will prevent UART from 'hanging'(stopping) due to overrun condition( more than 3 characters coming in before program handles them).
3) delay_ms(65535) is over 1 minute( 65.535 seconds)..... way too ling for ANY serial communications...
4) you need to add some kind of verification that EACH 'print to GPS' is correct. Usually you take an unused pin,configure as a software serial port, and send messages to a PC terminal program OR send to a local LCD module. You need this for properly debugging what is going wrong.
hth
jay |
thanvuongv
Posted: Sat Apr 26, 2014 9:25 am |
thank you. I repaired baud.
thanvuongv
Posted: Sat Apr 26, 2014 9:45 am |
ok
Posted: Sat Apr 26, 2014 9:54 am |
Just a comment.
A 'delay_ms(65535);', is _65.5 seconds_. 7 seconds is only delay_ms(7000).... |
thanvuongv
Posted: Sat Apr 26, 2014 11:16 am |
Thank for your help.
My project is complete |
