How to configure Timer to measure time between interrupts
40inD
PostPosted: Tue Apr 22, 2014 2:04 am     Reply with quote
How to configure Timer to measure time between ext ints in msec?
measuring range - 800 - 1200 ms.
PIC18F258 @8MHz
RF_Developer
Re: How to configure Timer to measure time between interrupt
PostPosted: Tue Apr 22, 2014 4:25 am     Reply with quote
If you want good resolution and low jitter, this is a job for a CCP, not a timer on its own. Set up the timer to clock at the desired timing resolution, e.g. 0.01ms, then use the CPP to capture when triggered by your external event. Firmware has to deal with reading the capture values and with timer roll-overs in ISRs.
If the timing resolution is large and some jitter, of the order of us, is acceptable, then you can do the capture in firmware, i.e. use the signal as an external interrupt and capture the count of a freerunning timer in the ISR, taking care to deal with the non-atomic nature of a 16 bit counter.
Both solutions suffer from the limited count length of timers: its difficult to have both good resolution AND long time before roll-over of the timer. So,with either solution, you're probably going to have to count roll-overs between timing events.
PostPosted: Tue Apr 22, 2014 4:32 am     Reply with quote
You don't.....
What you do is count faster, and then divide the result.
The most flexible prescaler, is on timer0. 8 binary divisions of 2MHz available. So 1MHz down to 7812.5Hz in multiples of 2. Use /16, which then gives counting at 125000Hz (the lowest frequency that is still an integer multiple of your target), and divide by 125.
40inD
PostPosted: Tue Apr 22, 2014 5:02 am     Reply with quote
The hardware is not editable. Event pulse comes to the INT_EXT pin.
So, i think the algorythm must be like this:
#INT_EXT
   void get_period()
   period=get_timer0();
   set_timer0(0);
setup_timer_0(RTCC_INTERNAL|RTCC_DIV_64); //2.1s overflow @8MHz
for time about 1000 ms between interrupts the "period" will be about 32000. Im right?
Then its need to convert the period value into msec.
asmboy
PostPosted: Tue Apr 22, 2014 7:52 am     Reply with quote
with the code you just posted - i think you need to also do a dummy read of the port_b register to re enable ints correctly
and
might want to consider making VAR "period"
be a circular buffer array - depending on how often the EXT interrupt might be taken.
also consider that if you have other INTS enabled, the number of cycles between the EXT_INT pin assertion - and your EXT ISR entry may vary, adding to error.
40inD
PostPosted: Thu Apr 24, 2014 1:25 am     Reply with quote
Is this really need for INT_EXT?
I thought it was only for INT_RB.
PostPosted: Thu Apr 24, 2014 1:31 am     Reply with quote
Correct.
He had a momentary lapse (as I often do), and thought you were using the interrupt on change.
