what are the steps to read a digital input like toggle swtch
Goto page 1, 2  Next
uma
PostPosted: Sat Apr 19, 2014 12:29 am     Reply with quote
give me the basic idea to write code to read a digital input using 16F877a in CCS compiler and to display a message as that particular" DI is high" in LCD . waiting for the reply.
uma
Application Engineer,
ETPL
Mike Walne
PostPosted: Sat Apr 19, 2014 2:33 am     Reply with quote
Start by doing an LED flasher.
When it flashes at the correct speed you know the compiler & PIC are working properly.
Progress to making a switch control the LED.
Next get the LCD to do "Hello World".
Finally merge the switch and LCD codes.
CCS provides schematics for the hardware, and examples for all the code.
Mike
uma
PostPosted: Sat Apr 19, 2014 3:05 am     Reply with quote
OK sure ,i will come back with the concept again.thank you.
uma
ETPL
ezflyr
PostPosted: Sat Apr 19, 2014 5:34 am     Reply with quote
Look at the 'input' function....
If (input(Pin_A0))
    Printf("Pin A0 is high\n\r");
Else
    Printf("Pin A0 is low\n\r");
John
gpsmikey
PostPosted: Sat Apr 19, 2014 8:57 am     Reply with quote
Don't forget you have to debounce the switch or you will get LOTS of switch activations Shocked
mikey
mikey
PostPosted: Sat Apr 19, 2014 5:29 pm     Reply with quote
If your project is about reading a switch, this thread has links to several
switch debounce routines:
http://www.ccsinfo.com/forum/viewtopic.php?t=42285
If you just want a simple program to change the state of an LED when
you push a button, this thread has a simple example program to do that:
http://www.ccsinfo.com/forum/viewtopic.php?t=47380&start=8
uma
is the format rgt to link led ,Lcdand switch? getting error
PostPosted: Mon Apr 28, 2014 6:36 am     Reply with quote
I am getting error as numeric expression is expected. I want to on/off switch and corresponding LED as a do should be on/off. Msg is respectively displayed in LCD.
#include <16f877a.h>
#fuses XT,NOWDT,NOPROTECT,BROWNOUT,PUT,NOLVP
#define Button Pin_C4;
#define Led Pin_B4;
#include <lcd.c>
    //lcd_putc,("/f welcome to ETPL");
    //lcd_putc,("/n LCD interface");
    If(input(Pin_C4))
    Printf(" Pin C4 is high\n\r");
    output_B(0);
    output_high(Pin_B4);//PIN_B4=1;
   Else
    Printf("Pin C4 is low/n/r");
uma
ETPL
alan
PostPosted: Mon Apr 28, 2014 6:53 am     Reply with quote
If(input(Pin_C4))
output_B(0);
Else
You need to add the brackets as shown.
bkamen
PostPosted: Mon Apr 28, 2014 8:17 am     Reply with quote
For what it's worth,
I'm a HUGE fan of ALWAYS encapsulating conditional statements with brackets/braces (whatever the language uses).
I never use:
 If ()
    statement;
    statement;
I ALWAYS use:
 If () {
    statement;
 } else {
    statement;
I've seen too many bugs of people adding things to conditionals that didn't use braces and when they added stuff, the braces didn't go in, the extra code didn't run right.
drh
PostPosted: Mon Apr 28, 2014 8:32 am     Reply with quote
[/code]
#define Led Pin_B4;
#i
nclude <lcd.c>
Remove the ; from the PIN_C4 and PIN_B4 defines.
David
Mike Walne
Re: is the format rgt to link led ,Lcdand switch? getting er
PostPosted: Mon Apr 28, 2014 5:09 pm     Reply with quote
#define Led Pin_B4;
#include <lcd.c>
    If(input(Pin_C4))
    output_B(0);
   Else
1) Code offered is neither complete nor compilable.
2) lcd_init(); should not be inside while loop. Only needs to happen once.
3) Insert a 1 second delay before initialising LCD to allow device to settle.
4) You have defined Button and Led, then do not use them!!!
Mike
uma
PostPosted: Mon Apr 28, 2014 11:09 pm     Reply with quote
I am connecting the button switch to pin C4 and LED to Pin B4, then how can i mention that in the code mr. mike, especially to link everything in the main code?
uma
ETPL
uma
PostPosted: Mon Apr 28, 2014 11:28 pm     Reply with quote
After putting Brace,
my code is,
#define Led Pin_B4;
#include <lcd.c>
    If(input(Pin_C4))
    output_B(0);
    //PIN_B4=1;
   Else
link for screen shot:
http://s28.postimg.org/rdpepndel/screen_with_connection.jpg
uma
ETPL
Mike Walne
PostPosted: Tue Apr 29, 2014 2:23 am     Reply with quote
Your code is still neither complete nor compilable.
1) Count the opening and closing braces.
2) I said put the delay BEFORE the lcd_init().
3) You are still not using the Button and Led defines in your code.
Mike
uma
PostPosted: Wed Apr 30, 2014 12:56 am     Reply with quote
sorry i put the braces correctly,the mistake occurred in the above code while copying.but i didnot understand that u have told me i have not used the defines LED and button,i used it as pin C4 and B4, then how to use it?
uma
ETPL
Goto page 1, 2  Next
Page 1 of 2
