Error does not make sense
jameszum
PostPosted: Fri Apr 11, 2014 2:36 pm     Reply with quote
Good Afternoon
I am using the CCS compiler V5.024 with MPLABX V 2.05.
    CLEAR_INTERRUPT(INT_EXT0);// if an interrupt occurred clear it
    enable_interrupts(INT_EXT0); // turn the external interrupt back on
    CLEAR_INTERRUPT(INT_EXT2);// if an interrupt occurred clear it
    enable_interrupts(INT_EXT2); // turn the external interrupts back on
------The line below  was added  -----------------
and i now get an error
Error#12 Undefined identifier GLOBAL
is GLOBAL no longer defined in the CCS compiler ?, or is this a problem
with the MPLABX
PostPosted: Fri Apr 11, 2014 2:46 pm     Reply with quote
What PIC are you using ? All of this stuff varies, based on what PIC
and what compiler you are using.
jeremiah
PostPosted: Fri Apr 11, 2014 5:43 pm     Reply with quote
PIC24s and dsPICs for example use INTR_GLOBAL instead.
