Trouble with PWM and ADC of 12F683
tien168bn
PostPosted: Fri Apr 04, 2014 7:53 am     Reply with quote
Hi guys. I have a trouble with PWM and ADC of PIC 12F683. My project is change ADC level at GP0 to change PWM at GP2, use module CCP1. But when I change ADC level, PWM not change. Somebody help me Smile Thank a lots.
#include <12F683.h>
#device adc=10
#fuses INTRC_IO, NOWDT, NOCPD, NOPROTECT, MCLR, NOPUT, BROWNOUT
#byte GPIO = 0x05
#bit vr1 = gpio.0 //VR
#bit vr2 = gpio.1 //CBN
#bit button = gpio.5
#bit motor = gpio.2
#bit led = gpio.4
int16 value;
void initCCT(void)
   setup_oscillator(OSC_4MHZ);
   setup_adc_ports(sAN0|sAN1|VSS_VDD); //Set GP0-GP1 as analog input, other pins as digitals I/O
   setup_adc(ADC_CLOCK_DIV_8);//(ADC_CLOCK_DIV_8); //Divisor for 4 MHz crystal
   set_adc_channel(sAN0|sAN1);
   setup_comparator(NC_NC);
   setup_ccp1(CCP_PWM);// Set the PWM frequency for 245 Hz (with a 4 MHz crystal)
   setup_timer_2(T2_DIV_BY_16, 254, 1);
   set_tris_a(0x23);
   initCCT();
   while(true)
       set_adc_channel(sAN0);
       delay_us(10);
       value = read_adc();// 10-bit ADC result
       set_pwm1_duty(value);
https://www.flickr.com/photos/120032952@N04/13623746254/
https://www.flickr.com/photos/120032952@N04/13623388855/
alan
PostPosted: Fri Apr 04, 2014 8:55 am     Reply with quote
Set_ADC_channel(0) or set_ADC_channel(1).
tien168bn
PostPosted: Fri Apr 04, 2014 9:46 am     Reply with quote
I tried. PWM ok, but ADC not run. I change ADC but PWM not change
stinky
PostPosted: Fri Apr 04, 2014 11:21 am     Reply with quote
the schematic shows vr1 and vr2 connected as variable resistors.
Perhaps you intended to use them as potentiometers so you could vary the voltage being read on those pins.
PostPosted: Fri Apr 04, 2014 12:33 pm     Reply with quote
He means you should connect your trimpots like this:
http://dm.risd.edu/pbadger/PhysComp/pmwiki/uploads/Devices/Pot.jpg
Power on one end, ground on the other, and connect the middle pin
(the wiper) to the PIC's analog input.
PostPosted: Fri Apr 04, 2014 1:02 pm     Reply with quote
Yes. As it stands you always have the same voltage on the pins, just a varying resistance....
The point about 'or', was the line:
The set_adc_channel function accepts _one_ channel only at a time. Doesn't allow values to be OR'ed together, and doesn't select the sANx numbers. Just 0, 1, 2 etc., for the channel to be selected.
So the channel should be selected with:
set_adc_channel(0);
tien168bn
PostPosted: Fri Apr 04, 2014 8:48 pm     Reply with quote
Thank all. I will try again. :D
tien168bn
PostPosted: Fri Apr 04, 2014 8:56 pm     Reply with quote
Hi, thank so much. The error is my schematic. it run. thank you Very Happy
