rrb011270
I guess this is not the right forum |
Posted: Thu Oct 16, 2003 7:50 pm |
Mabuhay!
I have a project that will use the RS485 thing... I have the system running with a few protocols implemented... but I decided if it is possible to have my power supply distributed to a network using bus..
I used a 6-wire bus cable and I have three vacant... I would use this to transmit my dc power to the different slave devices...
Anybody in the community can provide info, site and/or schematics as a startup..
Thnx |
MikeW
Joined: 15 Sep 2003 Posts: 184 Location: Warrington UK
Posted: Fri Oct 17, 2003 1:41 am |
I have used RS485 extensively.
I used RJ45 plugs,sockets and cable.
Its widely available, since it is Ethernet hardware.
I use all 8 wires,
1 common
2 +9volts
3 Data +
4 Data -
5 Data -
6 Data +
7 +9volts
8 common
that way, it doesnt matter which way you crimp the plug to the cable, also you have redundancy should one pin go faulty
the +9volts gets regulated down to +5 as necessary on each module
I current limit the +9volt power supply with a resettable polyfuse.
dont forget TVS diodes for transient protection on the data lines
you can get 4 in a SOT23-6 package
Hope this helps. |
Posted: Fri Oct 17, 2003 2:26 am |
If ok can u provide the schematics in applying your setup...
I want to see the complete picture on how u place the TVS at the data lines.
Thnx
MikeW wrote: | I have used RS485 extensively.
I use all 8 wires,
1 common
2 +9volts
3 Data +
4 Data -
5 Data -
6 Data +
7 +9volts
8 common
Hope this helps. |
rrb011270
Posted: Fri Oct 17, 2003 2:34 am |
Mabuhay!
Would it be possibel if u can share the schematics of power supply circuits? What's this TVS thing?
Which do u think is more reliable the DC or AC implementation?
MikeW wrote: |
I use all 8 wires,
1 common
2 +9volts
3 Data +
4 Data -
5 Data -
6 Data +
7 +9volts
8 common
Hope this helps. |
Posted: Fri Oct 17, 2003 3:59 am |
Hi there!
I am currently doing somthing very similar with RS485 data and power on the same cable.
I am still in the early stages of developement (not hardware as yet) but this is what I have done.
I am using RJ45 connectors, with standard Cat5 networking cables so it is very cheap and easy to maintain. I am using the same connections as described on the website :-
http://www.aptcommunications.com/ncode.htm
(there are plenty of others aswell, a searchs along the lines of Cat5, connections, diagrams etc should show loads).
Rx+ and Rx- must be on a twisted pair, as must be Tx+ and Tx-, to stop EMI and EMC problems.
I am then using pins 4 and 7 to supply 5V, with pins 5 and 8 supplying the 0V referance. There is a new Power Over Ethernet (PoE) standard, which specifies different connections to this (which I am currently looking into, but I dont seem to be able to find much data on it - any ideas, anyone ).
As for how to get the power into the system, I am not quite that far on yet, but I suspect a box with DC in, RS485(no power) in and RS485(with power) out will be how I do it, the DC simply being connected to the appropriate pin of the connector.
Hope this is of some use
Richard |
SherpaDoug
Posted: Fri Oct 17, 2003 1:06 pm |
A lot of scientific instruments use 12VDC and RS485 on a 4 pin connector like this:
pin 1 Ground
pin 2 Data +
pin 3 +12VDC
pin 4 Data -
Be sure if you are using RS485 (one bidirectional data pair) or RS422 (one data pair each way).
I read one article about a Power Over Ethernet protocol and it was very complex with power level interrogation and negotiation. It was far too complex for anything I build until someone makes a dedicated power control processor for it. _________________ The search for better is endless. Instead simply find very good and get the job done. |
