LM35 sensor
faridh3
LM35 sensor
PostPosted: Thu Apr 03, 2014 4:47 am     Reply with quote
i need to do a driver for this sensor but just for positive temp. i need to use only AN0, using no interrupts.
I am only getting the ADC result with this code
int8 ADC_val;
setup_adc_ports(AN0);
setup_adc(ADC_CLOCK_INTERNAL|ADC_TAD_MUL_12);
set_adc_channel(0);
ADC_val = read_adc();
printf(lcd_putc, "ADC val: %03u", ADC_val);
This code is not showing on the LCD the temperature, but the ADC result.
how can i convert it to celsius ?
Farid
ezflyr
PostPosted: Thu Apr 03, 2014 4:57 am     Reply with quote
Sorry, this question is too embarrassingly easy to solve on your own with a little bit of research in the forum archives, and using Google. You'll learn a lot more if you solve this problem yourself rather than asking us to spoon feed you.....
Good Luck!
John
faridh3
PostPosted: Thu Apr 03, 2014 5:08 am     Reply with quote
ezflyr wrote:
Good Luck!
John
I am sorry but i need this urgently .. i am new at this.
I also have to use a 5 times amplifier for the LM35.
ezflyr
PostPosted: Thu Apr 03, 2014 6:23 am     Reply with quote
faridh3,
Your question, and the whole manner in which you ask it screams "late homework assignment"..... It's NOT the purpose of the forum to do your work for you, 'Urgent' or not!
As a test, I did a forum search using 'LM35' as the search criteria, and found the EXACT answer to your question in under 2 minutes! Come on, I really hate to beat you up, but YOU could have found the solution to the problem on your own faster than posting a request for help here.....
John
faridh3
PostPosted: Thu Apr 03, 2014 6:25 am     Reply with quote
ezflyr wrote:
faridh3,
John
Your are right i know .. i've been searching for 1hour .. i am new at the ADC world .. so thats why.
and its not a homework .. i have a project to do for the next month.
Farid
PostPosted: Thu Apr 03, 2014 7:03 am     Reply with quote
simple google 'lm35 ccs c code' and you get about 5000 hits....
some within the first 4 pages have EXACTLY what you require..
..well, after you adjust the code to compensate for your x5 amplifer.
hth
jay
faridh3
PostPosted: Thu Apr 03, 2014 7:21 am     Reply with quote
hth
jay
Thank you jay
Gabriel
PostPosted: Thu Apr 03, 2014 8:45 am     Reply with quote
I'll jump in since you sent me a PM.
If you use the code on this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=50320
You will get a nice ADC reading for Positive temperatures only.
If you simply multiply said reading by your ADC constant, your result is in degrees Celcius... thats the standard LM35 output "format".
From there you just have to use the right printf() format.
Both of which you can find in my LM35 "Driver"....
(my "driver" is just a fancy adc averaging function that handles +/- temperatures).
G.
CCS PCM 5.078 & CCS PCH 5.093
faridh3
PostPosted: Thu Apr 03, 2014 10:58 am     Reply with quote
G.
Thanks G.
