Help interrupts in pic16f877a
khongyeuem
PostPosted: Mon Mar 31, 2014 10:07 am     Reply with quote
I have read datasheet of pic16f877a.They say global interrupt bit is automatically blocked(GIE=0) when have interupts occur.but I noticed that when people write programs,the first thing is disable_interrupts(global) and after implement ISR then enable_interupts(global).It have automatically blocked.Can you explain to me please?
anhyeuem
PostPosted: Mon Mar 31, 2014 11:05 am     Reply with quote
They don't.....
Look at the example files. None of the ISR's ever calls 'enable_interrupts(GLOBAL)'.
Search here, and you will find the (thankfully) few people doing this, being told quite forcibly _not_ to do it. It is lethal (to the program). The 'disable' won't cause any problem (since the interrupt is already disabled when you enter the ISR code), but 'enable_interrupt(GLOBAL)', inside an ISR, can result in the ISR being called again inside itself, and will then crash the code.
The key point is that the return instruction used in an ISR (RETFIE) enables the global interrupt _after_ it executes, ensuring the code has left the ISR before the interrupts are re-enabled....
