Not able to receive gps data*** Locked - MikroC is off-topic
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
meghna
PostPosted: Thu Mar 27, 2014 1:23 am     Reply with quote
Here is my code to get data from gps module and to display it on lcd. I am using pic16f887 controller and Micro C software. So please help me out as soon as possible in my code.
sbit LCD_RS at RB4_bit;
sbit LCD_EN at RB5_bit;
sbit LCD_D4 at RB0_bit;
sbit LCD_D5 at RB1_bit;
sbit LCD_D6 at RB2_bit;
sbit LCD_D7 at RB3_bit;
sbit LCD_RS_Direction at TRISB4_bit;
sbit LCD_EN_Direction at TRISB5_bit;
sbit LCD_D4_Direction at TRISB0_bit;
sbit LCD_D5_Direction at TRISB1_bit;
sbit LCD_D6_Direction at TRISB2_bit;
sbit LCD_D7_Direction at TRISB3_bit;
// Variables
int i = 0;
int received = 0;
char DataType[] = "GPXXX";
char NMEA[] = "$xxxxx,xxxxxxxxx,xxxx.xxx,x,xxxxx.xxx,x,x,xx,x.x,xxx.x,x,xx.x,x,,*xx";
             //$GPRMC,hhmmss.ss,A,llll.ll,a,yyyyy.yy,a,x.x,x.x,ddmmyy,x.x,a*hh
             //$GPRMC,220516,A,5133.82,N,00042.24,W,173.8,231.8,130694,004.2,W*70
char received;
// End Variables
 PORTB = 0xFF;
 TRISB = 0xff;
 ANSEL = 0;
 ANSELH = 0;
 C1ON_bit = 0;
 C2ON_bit = 0;                        // Set Port B as output port
        SPBRG=9600;                // Fill SPBRG register to set the baud rate
        RCSTA.SPEN=1;                        // To activate serial port (Tx and Rx pins)
        RCSTA.CREN=1;                        // To enable continuous reception
        Lcd_Init();
        UART1_Init(9600);
 Lcd_Cmd(_LCD_CLEAR);      // Clear display
 Lcd_Cmd(_LCD_CURSOR_OFF); // Cursor off
 // LCD Stuff
 LCD_Out(1, 1, "Lat                 ");
 LCD_Out(2, 1, "Lon                 ");
 LCD_Chr(1, 10, 0xB0);  //Degree Character
 LCD_Chr(2, 10, 0xB0);  //Degree Character
 LCD_Chr(1, 13, 0xB4);  //' Character
 LCD_Chr(2, 13, 0xB4);  //' Character
  if (UART1_Data_Ready() == 1)
   received =  UART1_Read();
   if (received == '$')  // Check if sentence begins.
        received = 0;
        do
           UART1_Read_Text(DataType, ",", 10);  // Capture GPXXX word
           received = 1;
        while(received == 0);
        // If it is GPGGA Data, then acquire it.
        if ((DataType[2] == 'G') && (DataType[3] == 'G') && (DataType[4] == 'A'))
          received = 0;
          do
             UART1_Read_Text(NMEA, "*", 100);   // Stop at *XX checksum data
             received = 1;
          // Fill LCD with relevant data
          // Latitude
          LCD_Chr(1, 8, NMEA[10]);
          LCD_Chr(1, 9, NMEA[11]);
          LCD_Chr(1, 11, NMEA[12]);
          LCD_Chr(1, 12, NMEA[13]);
          LCD_Chr(1, 14, NMEA[15]);
          LCD_Chr(1, 15, NMEA[16]);
          LCD_Chr(1, 16, NMEA[17]);
          LCD_Chr(1, 17, NMEA[18]);
          LCD_Chr(1, 18, NMEA[19]);
          LCD_Chr(1, 20, NMEA[21]);
          // Longitude
          LCD_Chr(2, 7, NMEA[23]);
          LCD_Chr(2, 8, NMEA[24]);
          LCD_Chr(2, 9, NMEA[25]);
          LCD_Chr(2, 11, NMEA[26]);
          LCD_Chr(2, 12, NMEA[27]);
          LCD_Chr(2, 14, NMEA[29]);
          LCD_Chr(2, 15, NMEA[30]);
          LCD_Chr(2, 16, NMEA[31]);
          LCD_Chr(2, 17, NMEA[32]);
          LCD_Chr(2, 18, NMEA[33]);
          LCD_Chr(2, 20, NMEA[35]);
      received = "x";
PostPosted: Thu Mar 27, 2014 1:43 am     Reply with quote
Read what this forum is for....
You are using _Micro C_. This forum is for _CCS C_. Go to a Micro C forum.
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
