PIC18F66K22 PORTC doesn't change state some bits
Fabri
PostPosted: Tue Mar 25, 2014 2:51 pm     Reply with quote
Hi to all,
I'm in trouble with PIC18F66K22. PORTC pin C0 and C1 doesn't change state after drive in firmware. Same firmware work fine with PIC18F46K22.
This is test program:
#define PIC_66K22      // PICC4H
   #include "18F66K22.h"
   #if defined(debug)
   #fuses HSM,DEBUG,NOWDT,NOPROTECT,NOPUT,NOBROWNOUT,NOCPD,BORV18,NODEBUG,NOCPB,STVREN,NOPLLEN,NOFCMEN
   #device ADC=12 icd=true
   #else
   #fuses HSM,NODEBUG,WDT,PROTECT,PUT,CPD,BORV18,CPB,STVREN,NOPLLEN,NOFCMEN
   #device  ADC=12
#device *=16
#BYTE   PORTA   = 0x0F80
#BYTE   PORTB   = 0x0F81
#BYTE   PORTC   = 0x0F82
#BYTE   PORTD   = 0x0F83
#BYTE   PORTE   = 0x0F84
#BYTE   PORTF   = 0x0F85
#BYTE   PORTG   = 0x0F86
#byte   ODCON1= 0xF29
#byte   ODCON2= 0xF28
#byte   ODCON3= 0xF27
#byte   LATC = 0xF8B
#fill_rom 0x00
#use delay(clock=16000000,RESTART_WDT)
//Definisci I/0 in base allo schema
restart_wdt();
set_tris_a(0x00);
set_tris_b(0x00);
set_tris_c(0x00);
set_tris_d(0x00);
set_tris_e(0x00);
set_tris_e(0x00);
set_tris_f(0x00);
PORTA = (0x00);
PORTB = (0x00);
PORTC = (0x00);
PORTD = (0x00);
PORTE = (0x00);
PORTF = (0x00);
PORTG = (0x00);
LATC=0xff;
ODCON1=0;
ODCON2=0;
ODCON3=0;
SETUP_CCP1(CCP_OFF);
SETUP_CCP2(CCP_OFF);
SETUP_CCP3(CCP_OFF);
   while(true) {
      output_high(PIN_C2);
      output_high(PIN_C1);
      output_high(PIN_C0);
      output_high(PIN_D7);
      delay_ms(10);
      output_low(PIN_C1);
      output_low(PIN_C0);
      output_low(PIN_D7);
      output_low(PIN_C2);
      delay_ms(10);
When I drive on PIN_C2 and PIN_D7 they change state without problem but when I drive on PIN_C1 and PIN_C0 I can see the bit change state in LATC register but not in PORTC. I tested in debug with ICD2, ICD3 and run in hardware.
What is wrong ?
I use CCS V4.135.
PostPosted: Tue Mar 25, 2014 2:58 pm     Reply with quote
See this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=51950
Fabri
PostPosted: Tue Mar 25, 2014 3:34 pm     Reply with quote
Opss...
I replied to the wrong thread.... Embarassed
Thanks PCM. Now it's work.
