Problem with PIC16F628A And Serial LCD
amjad_alahdal
View user's profile Send private message Yahoo Messenger MSN Messenger
PostPosted: Tue Mar 25, 2014 10:59 am     Reply with quote
Hi everyone,
I am using a PIC16F628A, and a sparkfun serial LCD,,
Well, I have a problem in displaying. Sometimes, the LCD works well, others it prints some strange characters such as Omega Symbol or Pi Symbol.
I am not using a Crystal for this PIC because, it works well without it.
Do I have to connect a crystal ?
If no, then I am in the right path.
If Yes, I need to tell you that I have already connected an 8MHz Crystal. Activated the HS in the FUSES, and didn't work.
In the following program, I am using an interrupt which I tested already, it worked well, but still having a displaying problem. Sometimes the LCD froze.
#include<16F628A.h>
#DEVICE PASS_STRINGS = IN_RAM
#FUSES NOWDT                //No Watch Dog Timer
#FUSES INTRC                    //Internal RC Osc
#FUSES PUT                      //Power Up Timer
#USE DELAY(CLOCK = 4M)
#use rs232(baud=9600,xmit=PIN_B4,stream= COM_LCD)
#include<lcd.h>
static unsigned int16 counter ;
// inerrupt subroutine function.
#int_EXT
void Encoder_isr() {
counter++;
   delay_ms(2000);
   lcd_clear();
   fprintf(COM_LCD,"Hello");
   enable_interrupts(INT_EXT); //Activate the inerttupt
   ext_int_edge( L_TO_H );      //the counter will count when the click goes from Low to High
   clear_interrupt(INT_EXT);   //Clearing the interrupt for better counting
   enable_interrupts(GLOBAL);  //Activate the Global interrupt of the PIC
   while (TRUE)
      lcd_cursor_move(2,1);
      fprintf(COM_LCD,"%ld",counter);
this is the LCD
https://www.sparkfun.com/products/9396
why do I not use the regular LCD?
1- The pins are few
2- They don't sell it in my city.
PostPosted: Tue Mar 25, 2014 11:56 am     Reply with quote
#int_EXT
counter++;
You are using a software UART and you are interrupting the character
transmission and destroying the UART bit timing. That's the reason.
There are two possible solutions. The easiest and best one is to use
the hardware UART. Just specify UART1 as the parameter and don't
specify any pins. The compiler will automatically use the hardware
UART and it will use the two hardware UART pins, TX and RX.
The 2nd solution is to add the DISABLE_INTS parameter to the existing
#use rs232() line above. This will disable interrupts while the software
UART is transmitting the bits for each character. But, your #int_EXT
routine will be blocked for a maximum of one character time, if the
software UART is transmitting when the #int_ext interrupt occurs.
