WRITE_EEPROM=ASYNC
iukhan
WRITE_EEPROM=ASYNC
PostPosted: Sat Mar 22, 2014 1:23 am     Reply with quote
I am a little bit confused about the warning about using #device WRITE_EEPROM=ASYNC, from the CCS manual:
WRITE_EEPROM=ASYNC
Prevents WRITE_EEPROM from hanging while writing is taking place. When used, do not write to EEPROM from both ISR and outside ISR.
Here what does it means outside ISR? To my understanding if ISR is the interrupt service routine than outside ISR mean the all the remaining routines excluding ISR. That means that I cannot write any where in my code. Which of course cannot be true. Please help.
gpsmikey
PostPosted: Sat Mar 22, 2014 8:45 am     Reply with quote
You are correct - it simply means do not have routines to write to the eeprom in both the main code and the ISR (since with Murphy's law in force, while you are writing to the eeprom in your main code, the ISR will go off and try to write to the eeprom as well). Either only write to the eeprom in the ISR, or better, only write to the eeprom in your main code. Set a flag in the ISR telling the main code to update the eeprom or whatever your needs are. The thing you need to prevent is the possibility of one write taking place and having a second one start while the first one has not completed.
mikey
mikey
PostPosted: Sat Mar 22, 2014 10:46 am     Reply with quote
Keyword in the sentence is 'both'. Either in one or the other, but not both.
iukhan
PostPosted: Sun Mar 23, 2014 1:42 am     Reply with quote
Got it. Thanks
