uart code
Green20
uart code
PostPosted: Thu Mar 20, 2014 6:42 pm     Reply with quote
Hi all
please how can I write a code like that by the CCS compiler , I can't find an instruction equivalent to it
if (uart_available())
c1 = getchar();
ezflyr
PostPosted: Thu Mar 20, 2014 6:52 pm     Reply with quote
The kbhit() function will tell you if a character is available. If you are using the hardware UART it's probably better to just use the int_rda interrupt rather than polling to see if a character is available.
John
Green20
PostPosted: Thu Mar 20, 2014 7:03 pm     Reply with quote
Thank you sooo much
Green20
PostPosted: Thu Mar 20, 2014 7:25 pm     Reply with quote
I'm sorry but please I need to clear a register but when I'm searching in the content of the CCS compiler I just found :
bit_clear(x,2);
so this clear only one bit of a register not all the content of it !!!
newguy
PostPosted: Thu Mar 20, 2014 7:31 pm     Reply with quote
x = 0;
Green20
PostPosted: Thu Mar 20, 2014 7:41 pm     Reply with quote
thank you again Smile
