pcd mac assembler instruction.
clarence
PostPosted: Tue Mar 18, 2014 2:21 pm     Reply with quote
Does the pcd compiler implement the full mac instruction with two register prefetch and increment.
MAC B, W2*W3, W2, [W5]+=2, W3, [W7]+=4
In this case W2 and W3 pointers are both updated in the same cycle.
The documentation is not really clear on this.
PostPosted: Tue Mar 18, 2014 5:08 pm     Reply with quote
Make a very small test program. Comment out the #nolist statement
in the PIC's .h file (so it will show all CCS "library" code). Make sure
the .LST file format is set for Symbolic in the CCS IDE or MPLAB project
build options menu. Then compile it and look at the .LST file.
Also use the forum search page for some historical problems in vs. 4.092:
http://www.ccsinfo.com/forum/viewtopic.php?t=38964
Also the CCS version list says:
5.018 A problem with the encoding on an inline assembly MAC or MSC instruction is fixed
