how to use goto / SOLVED
faridh3
PostPosted: Tue Mar 18, 2014 8:29 am     Reply with quote
I got an error for the way i used the 'goto' function
How am i supposed to use it ?
Thank you.
Farid
#include <18F4520.h>
#FUSES WDT128                   //Watch Dog Timer uses 1:128 Postscale
#FUSES XT                       //Crystal osc <= 4mhz for PCM/PCH , 3mhz to 10 mhz for PCD
#FUSES PUT                      //Power Up Timer
#FUSES NOPBADEN                 //PORTB pins are configured as digital I/O on RESET
#FUSES NOXINST                  //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#use rs232(baud=9600,parity=N,xmit=PIN_C6,rcv=PIN_C7,bits=8,stream=PORT1)
#include "LCD2x16.h"
   set_tris_a(0xD5);
   set_tris_b(0x55);
   set_tris_c(0x55);
   lcd_init();
   int i=1;
   int level;
   int counterR;
   int counterL;
   loop
   do
   counterR=6;
   counterL=5;
   level=input_state(PIN_A0);
   if(level==0)
      {output_low(PIN_A1);}
   else{
      output_high(PIN_A1);
      counterL--;
   level=input_state(PIN_A2);
   if(level==0)
      output_low(PIN_A3);
   else{
      output_high(PIN_A3);
      counterL--;
   level=input_state(PIN_A4);
   if(level==0)
      output_low(PIN_A5);
   else{
      output_high(PIN_A5);
      counterL=counterL-1;
   level=input_state(PIN_B0);
   if(level==0)
      output_low(PIN_B1);
   else{
      output_high(PIN_B1);
   level=input_state(PIN_B2);
   if(level==0)
      output_low(PIN_B3);
   else{
      output_high(PIN_B3);
   level=input_state(PIN_B4);
   if(level==0)
      output_low(PIN_B5);
   else{
      output_high(PIN_B5);
      counterR=counterR-1;
   level=input_state(PIN_B6);
   if(level==0)
      output_low(PIN_B7);
   else{
      output_high(PIN_B7);
   level=input_state(PIN_C0);
   if(level==0)
      output_low(PIN_C1);
   else{
      output_high(PIN_C1);
   level=input_state(PIN_C2);
   if(level==0)
      output_low(PIN_C3);
   else{
      output_high(PIN_C3);
   level=input_state(PIN_C4);
   if(level==0)
      output_low(PIN_C5);
   else{
      output_high(PIN_C5);
  level=input_state(PIN_C6);
   if(level==0)
      output_low(PIN_C7);
   else{
      output_high(PIN_C7);
   if(counterR==6 && counterL==5){
      goto loop;
   else{
      lcd_putc('\f');
      printf(lcd_putc, "<%d            %d>\nFARID / HABIB   ",counterL,counterR);
   while(i==1);
stinky
PostPosted: Tue Mar 18, 2014 8:41 am     Reply with quote
Best practice to avoid it and choose another method for program flow. http://xkcd.com/292/
bkamen
PostPosted: Tue Mar 18, 2014 12:00 pm     Reply with quote
the goto must go to a label identified as
label:
in your case, "loop:" (<-- That's a COLON, not a semi-colon.)
But it really should be avoided at all costs.
(I'll admit, I've seen some cases where it actually makes sense to use... but I still avoid it at all costs.)
Your case is not one of them.
faridh3
PostPosted: Tue Mar 18, 2014 12:02 pm     Reply with quote
Thank you guys
I have worked without using it, i found a way.
bkamen
PostPosted: Tue Mar 18, 2014 12:09 pm     Reply with quote
Then considering marking the topic with "SOLVED" in the subject so people know..
and posting your solution.
-Ben
faridh3
PostPosted: Tue Mar 18, 2014 12:21 pm     Reply with quote
I am sorry but i am new at this .. how can i mark it as solved ?
PostPosted: Tue Mar 18, 2014 12:25 pm     Reply with quote
As the original poster, simply 'edit' the Subject line and include 'solved'.
hth
jay
