madhunica
this is the lcd display program |
Posted: Mon Mar 17, 2014 6:10 am |
i have no error & warnings.... but the simulation is not come... can you help me ?
Code: | #include <16F877A.h>
#DEVICE ADC=10
#include <string.h>
#include <ctype.h>
#include <stdlib.h>
#use delay(clock=12000000)
#use rs232(baud=9600,xmit=PIN_C6,rcv=PIN_C7,TIMEOUT=5000)
//#include <flex_lcd.c>
#fuses hs, nowdt, nolvp, noprotect //Config
#use delay (clock = 12000000) //12MHz Crystal
//#define T0_INTS_PER_SEC76 // (20,000,000/(4*256*256))
#define T1_INTS_PER_SEC 46 // (12,000,000/(4*1*65536))
byte int_count1;
#define lcd_port output_d
void Timer1_ISR(void);
void init(void); //Function Prototype
void busy_test(void);
void display(void);
void send_command(void);
void send_data(void);
//void putdat_lcd(int data);
unsigned char PORTE, TRISE, PORTD, TRISD, RS, RW, E, BF;
unsigned char command, data;
char voltage[8];
char current[8];
char time[8];
unsigned int16 value=0;
int i, sec,dval,dval2=0;
//#DEVICE ADC=10;
#byte PORTE = 0x07
#byte TRISE = 0x87
#byte PORTD = 0x08
#byte TRISD = 0x88
#bit RS = PORTE.0
#bit RW = PORTE.1
#bit E = PORTE.2
#bit BF = PORTD.7
#INT_TIMER1
//setup_timer_1(T1_DISABLED);
if(--int_count1==0)
sec++;
int_count1=T1_INTS_PER_SEC;
//setup_timer_1(T1_INTERNAL|T1_DIV_BY_8);
//output_(0x00);
//Set_Timer1(1000);
//TMR1L:=0x18;
void displayVoltage(int adc) {
char voltage[9];
sprintf(voltage, "%f", (float)adc * .01960784); // Converts adc to text
voltage[4] = '\0'; // Limit shown digits to 3
// glcd_rect(45, 18, 69, 25, YES, OFF); // Clear the old voltage
// glcd_text57(45, 18, voltage, 1, ON); // Write the new voltage
setup_timer_1(T1_DIV_BY_1|T1_INTERNAL);
set_timer1(0);
// ClearBit(TMR1IF);
// TMR1H =0xFC;
// TMR1L:=0x18;
//SetBit(TMR1IF);
//INTCON=0xC0;
sec=0;
//SetBit(TICON);
//set_timer1(1000);
init();
busy_test();
command = 0x81; //Set DDRAM Address To 0x00
send_command();
delay_ms (10);
busy_test();
data = 'C';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
data = 'R';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
data = 'E';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
data = 'A';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
data = 'T';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
data = 'I';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
data = 'N';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
send_data();
delay_ms (10);
busy_test();
send_data();
delay_ms (10);
busy_test();
send_data();
delay_ms (10);
busy_test();
data = ' ';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
send_data();
delay_ms (10);
busy_test();
send_data();
delay_ms (10);
busy_test();
send_data();
delay_ms (10);
busy_test();
data = 'L';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
data = 'Y';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
data = 'S';//0x50; //Display "P"
send_data();
delay_ms (10);
busy_test();
send_data();
delay_ms (10);
busy_test();
send_data();
strt:
display();
// sec++;
// display_2();
goto strt;
// if (getc()== 'A')
//first==getc();
delay_ms (100);
//goto strt;
//while (1)
void init()
set_tris_c(0x00);
set_tris_e(0x00); //Set Port C As Output
set_tris_d(0x00); //Set Port D As Output
output_e(0x00); //Clear Port C
output_c(0x00);
output_d(0x00); //Clear Port D
delay_ms (500); //Power-On Delay
//Busy Flag Valid Here
//busy_test(); //Check Busy Flag
// command = 0x38; //8-Bits, 2-Lines, 5x7 Dots
// send_command(); //Send Command To LCD
delay_ms (10);
// delay_us (500);
delay_ms (100);
command = 0x06; //8-Bits, 2-Lines, 5x7 Dots
delay_ms (1);
busy_test(); //Check BF
command = 0x0c; //Display Off, Cursor Off, No-Blink
delay_ms (1);
busy_test();
command = 0x01; //Clear Display
send_command();
delay_ms (5);
busy_test();
command = 0x02; //Increment Cursor Position, No-Shift
send_command();
// delay_ms (1);
// busy_test();
// command = 0x0F; //Display On, Cursor On, Blink
// send_command();
delay_ms (10);
void display()
setup_adc_ports(ALL_ANALOG);
set_adc_channel(0);
for(i=1;i<6;i++)
value=read_adc();
delay_us(10);
// Dcv = value* (5000/1024.0);
dval=value;
value = value * 49;
// lcd_gotoxy(1,2);
for(i=1;i<=7;i++)
voltage[i]=value%10;
value=value/10;
// setup_adc(ADC_CLOCK_INTERNAL);
// setup_adc_ports(ALL_ANALOG);
set_adc_channel(1);
for(i=1;i<6;i++)
value=read_adc();
delay_us(10);
dval2=value;
value = value * 49;
// lcd_gotoxy(1,2);
for(i=1;i<=7;i++)
current[i]=value%10;
value=value/10;
value = sec;
// value = value ;
// lcd_gotoxy(1,2);
for(i=1;i<=7;i++)
time[i]=value%10;
value=value/10;
busy_test();
command = 0xc0; //Set DDRAM Address To 0x00
send_command();
//Adval = (ADRESH * 256) + ADRESL;
// putdat_lcd(j);
// sprintf(line,"%02LX",j);
// busy_test();
// command = 0xd9; //Set DDRAM Address To 0x00
// send_command();
delay_ms (10);
busy_test();
data = 'V';//0x50; //Display "P"
send_data();
busy_test();
data = (':');//0x50; //Display "A"
send_data();
// busy_test();
// data = (voltage[7]+0x30);//0x50; //Display "S"
// send_data();
busy_test();
data = (voltage[6]+0x30);//0x50; //Display "S"
send_data();
busy_test();
data = (voltage[5]+0x30);//0x50; //Display "S"
send_data();
busy_test();
data = (voltage[4]+0x30);//0x50; //Display "S"
send_data();
busy_test();
data = (voltage[3]+0x30);//0x50; //Display "S"
send_data();
// busy_test();
// data = ('.');//0x4C; //Display "S"
// send_data();
busy_test();
data = (voltage[2]+0x30);//0x50; //Display "S"
send_data();
busy_test();
send_data();
busy_test();
data = (voltage[1]+0x30);//0x50; //Display "S"
send_data();
delay_ms (10);
void busy_test()
set_tris_d(0xFF); //Set Port D As Input
//RS = 0; //Command
//RW = 1; //Read Busy Flag
output_e(0x02);
delay_ms(1);
// delay_cycles (2); //Control Setup Time
//E = 1; //E-Line High
output_e(0x06);
delay_ms(1);
// delay_cycles (6); //Wait Data Return
// delay_us(
//if (BF == 0)
while ( input(PIN_D7));
set_tris_d(0x00); //Set Port D Back To Output
//E = 0; //E-Line Low
output_e(0x02);
// output_e(0x02);
//End while loop
} //End Function
void send_command()
output_d(command);
//RS = 0; //Command
//RW = 0; //Write Instruction
output_e(0x00);
delay_ms(1);
output_e(0x04);
delay_ms(1);
//delay_cycles (3);
// PORTD = command; //Put Command To Port D
delay_ms(1);
// delay_cycles (3); //Data Setup Time
output_e(0x00);
delay_ms(1);
//delay_cycles (1); //Control & Data Hold Time
lcd_port(data);
output_high(RS);
output_high(E);
delay_ms(1);
output_low(E);
delay_ms(6);
output_low(RS);
void send_data()
output_d(data);
//RS = 1; //Data
//RW = 0; //Write data
output_e(0x01);
delay_ms(1);
//delay_cycles (2); //Control Setup Time
output_e(0x05);
delay_ms(1);
//delay_cycles (3);
// PORTD = data; //Put Data To Port D
output_e(0x01);
delay_ms(1);
Joined: 01 Jul 2010 Posts: 9174 Location: Greensville,Ontario
Posted: Mon Mar 17, 2014 7:19 am |
comments.
1) nobody here can fix PROTEUS problems...so build real hardware.You should use a current PIC, the 877 is almost 20 years old, there are cheaper, better PICs to use.
2) start SMALL ! About 95% of your program is commented out or NOT required so get rid of everything that is not necessary,really start over.
3) I can't follow what you've done..it's way to 'complicated' a 'mixture' of code segments ,none will really work as a 'program'.
Get a PIC and cut the simple '1Hz flashing LED' program. CONFIRM that it works in real hardware.
Do NOT proceed until it does work !
THEN
cut code for the 'test LCD Hello World' program. CONFIRM that it does work in real hardware. I suggest using the 'flex_LCD driver' as it is KNOWN to work very well.
THEN
proceed with your school project.
hth
jay |
