RGB control
atoo
RGB control
PostPosted: Fri Mar 07, 2014 4:54 am     Reply with quote
Did that change an RGB LED
with two colors per timer2 and PWM
someone has a simple example to change the color of the RGB LED
without having to use CCP1 module only timer2 and duty cycle
Simple simple simple ... etc. Question Question Question
Mike Walne
PostPosted: Fri Mar 07, 2014 5:39 am     Reply with quote
Do a search for software PWM on this forum. It's been done loads of times before.
As with your previous posts, if/when you get stuck, show us what you've done, then someone here will help.
We're NOT going to give you the answers.
Mike
atoo
Atoo
PostPosted: Fri Mar 07, 2014 6:24 am     Reply with quote
of course not,
is logical
I do not want work to be done
already be prepared
only information that leads to a solution
grateful Rolling Eyes Cool
atoo
atoo
PostPosted: Mon Mar 10, 2014 4:27 pm     Reply with quote
I found the PWM module in mikroC
Only  people that someone translate for CCS C
because I'm beginner and would like to test !!
Question Question
dyeatman
PostPosted: Mon Mar 10, 2014 4:53 pm     Reply with quote
You need to search THIS forum for PWM and you would find this...among other things
http://www.ccsinfo.com/forum/viewtopic.php?t=50069
Google and Forum Search are some of your best tools!!!!
atoo
Atoo
PostPosted: Tue Mar 11, 2014 2:52 am     Reply with quote
dyeatman
I did not choose the mikro c
but the ccs c language
is the best ...
I would then translate mikro c for CCS C
as is, of mikro c for CCS C?
see the code
  pwm1_init(10000);  //configura o PWM para freq de 10Khz
  pwm1_set_duty(128);  //seta duty cycle para 50%
  pwm1_start();    //inicia geração do pulso
  delay_ms(100);   //espera 100 milissegundos
  pwm1_stop();     // Para a geração do pulso
  pwm1_set_duty(192);  //seta duty cycle para 75%
Thanks for the post and attention.
atoo
Atoo
PostPosted: Tue Mar 11, 2014 6:00 pm     Reply with quote
Someone ? Question Sad
PostPosted: Wed Mar 12, 2014 5:55 am     Reply with quote
You need to show us the entire program, not just a bit of it. WE have no idea which PIC you're using or your compiler version.
While I do have mikroCpro, CCS is FAR easier to understand and program with.
I know that English may be your second language and that the 'search' feature of this forum has a couple 'quirks'. It just takes practice to find what you want.
As previously stated, there are several programs on the forum.
hth
jay
atoo
PostPosted: Wed Mar 12, 2014 2:16 pm     Reply with quote
no no, I just want to translate to CCS C
I people please! earnestly ! Question
as it would be in CCS C ? the code ?
PostPosted: Wed Mar 12, 2014 2:26 pm     Reply with quote
We are not going to translate the code for you.
Go off by yourself, learn MikroC and CCS, and you do the translation.
Do not protest, do not beg for help, just learn to program and do it.
That's what the rest of us did.
asmboy
PostPosted: Wed Mar 12, 2014 3:50 pm     Reply with quote
allow me to let the rules of the forum do the talking:
3. Before posting a question, look for the answer first
4. When asking for help, please give as much relevant information as you can.
let me say in the kindest and most mindful way,
that I am positively encouraged to get involved
when the original poster has shown initiative and exerted
some effort to solve their own problem.
Revealing significant source code ,
a schematic where appropriate ,
and above all showing some patience -
is most likely to make me expend the time to respond.
language skill has little to do with it
INITIATIVE and personal effort-to-solve are the key.
atoo
PostPosted: Wed Mar 12, 2014 4:22 pm     Reply with quote
I understand
it's all right
Sad
