xericklmx
help cgram |
Posted: Wed Feb 26, 2014 7:47 pm |
I need help with this library, I can not make a hand on the LCD screen, this library is called lcd_driver.h, found in libraries sourceboots
// LCD with HD44780 drive chip
// Author(s): David Hobday, Pavel Baranov
// Date 15 November 2004
// Copyright(C) 2004-2010 Pavel Baranov
// Copyright(C) 2004-2010 David Hobday
// Copyright(C) 2004 Andrew Smallridge
// How to use - by David Hobday
// Remember when using LCD in 4 bit mode you must connect to the LCDs DB4-DB7 pins.
// *** For a list of functions, see the END of this file.
// The time delays used in the code should mean that it will work on PIC18 with
// 40MHz clock without any changes.
// The example below (which would work on a PIC16F84) operates the display
// in 4bit mode and requires the following connections:
// RS to RA3
// R/W to RA2
// E to RA1
// DB0 to None
// DB1 to None
// DB2 to None
// DB3 to None
// DB4 to RB4
// DB5 to RB5
// DB6 to RB6
// DB7 to RB7
// Add the following after #include <system.h> in you source file:
//#define LCD_ARGS 2, /* Interface type: mode 0 = 8bit, 1 = 4bit(low nibble), 2 = 4bit(upper nibble) */ \
// 1, /* Use busy signal: 1 = use busy, 0 = use time delays */\
// PORTB, TRISB, /* Data port and data port tris register */ \
// PORTA, TRISA, /* Control port and control port tris register */ \
// 3, /* Bit number of control port is connected to RS */ \
// 2, /* Bit number of control port is connected to RW */ \
// 1 /* Bit number of control port is connected to Enable */
//#include <lcd_driver.h> // include the LCD template code
// Revisions
// V1.10 David Hobday 03/03/2005
// 1) Improved documentation in file
// 2) Changed delays to delay_10us for usage on target with clock <= 4MHz
// 3) Changed template to make more friendly and obvious
// V1.11 18/03/2005
// David Hobday
// 1) Fixed operation with PIC18 - template arguments of incorrect type
// 2) Tested with PicDem2Plus board (4MHz PIC16F877/PIC18F452)
// 3) Added lcd_gotoxy function.
// 4) Added option to use display busy bit or time delays
// 5) Added overloaded lprintf function for ROM string
// 6) Added overloaded lprintf function to output numbers supported formats:
// "%d" - decimal
// "%X" - hex
// "%b" - binart
// example: display binary number six digits, '0' as file character.
// lprintf( "val:%06b", numb );
// 7) Other improvements/cleanup.
// V1.11 David Hobday 25/03/2005
// 1) Fixed bug with lprintf( "test:%d", 0 ); not printing a 0.
// 2) Added a few more comments in lprintf( const char*, int ) code
// V1.12 Jason Sobell 03/07/2005
// 1) Fixed display of unsigned integers >32767
// V1.13 David Hobday 08/07/2005
// 1) Removed code that is no longer needed (as val is now unsigned).
// 2) Tweaked Jason Sobell changes a little to reduce code size.
// V1.14 David Hobday 11/11/2005
// 1) Changed lcd_gotoxy function so that it works as expected with 20 x 4 display
char writeDelayType;
// LCD Commands ( Refer to LCD Data Sheet )
#define clear_lcd 0x01 // Clear Display
#define return_home 0x02 // Cursor to Home position
#define entry_mode 0x06 // Normal entry mode
#define entry_mode_rev 0x04 // Normal entry mode -reverse direction
#define entry_mode_scroll 0x07 // - with shift
#define entry_mode_scroll_rev 0x05 // reverse direction
#define system_set_8_bit 0x38 // 8 bit data mode 2 line ( 5x7 font )
#define system_set_4_bit 0x28 // 4 bit data mode 2 line ( 5x7 font )
#define system_set_reset 0x30 // Reset code
#define display_on 0x0C // Display ON - 2 line mode
#define display_off 0x08 // Display off
#define set_dd_line1 0x40 // Line 1 position 1
#define set_dd_line2 0xC0 // Line 2 position 1
#define set_dd_ram 0x40 // Line 1 position 1
#define write_data 0x00 // With RS = 1
#define cursor_on 0x0E // Switch Cursor ON
#define cursor_off 0x0C // Switch Cursor OFF
#define cursor_blink_on 0x0F // Cursor plus blink
#define cursor_shift_right 0x14 // Move cursor right
#define cursor_shift_left 0x10 // Move cursor left
#define display_shift_right 0x1C // Scroll display right
#define display_shift_left 0x18 // Scroll display left
#define WriteNoDelay 1
#define WriteControlled 0
// Interface type
#define LCD_8_BIT_MODE 0
#define LCD_4_BIT_LO_NIB_MODE 1
#define LCD_4_BIT_HI_NIB_MODE 2
// These macros make susequent code more readable, but can seem a little confusing
#define _LCD_RawWriteNibble LCD_RawWriteNibble <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_RawWriteNibbleInline LCD_RawWriteNibbleInline <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_Read LCD_Read <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_WaitForNotBusy LCD_WaitForNotBusy <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_Write LCD_Write <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_FunctionMode LCD_FunctionMode <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_DataMode LCD_DataMode <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_RawWrite LCD_RawWrite <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_ClockOut LCD_ClockOut <InterfaceType, UseBusy, DataPort, Data_PortTris, CtrlPort, Ctrl_PortTris, RS, RW, E>
#define _LCD_TEMPL template < unsigned char InterfaceType,\
unsigned char UseBusy,\
unsigned int DataPort, unsigned int Data_PortTris,\
unsigned int CtrlPort, unsigned int Ctrl_PortTris,\
unsigned char RS, unsigned char RW, unsigned char E>
_LCD_TEMPL
inline void LCD_FunctionMode( void )
volatile bit rs@CtrlPort.RS = 0;
_LCD_TEMPL
inline void LCD_DataMode( void )
volatile bit rs@CtrlPort.RS = 1;
inline void LCD_CycleMakeupDelay()
// Enable cycle time must be > 1000ns total for both reading and writing
// LCD_SetupDelay + LCD_EnablePulseDelay + LCD_HoldupDelay + LCD_CycleMakeupDelay >= 1000ns
// 200 + 500 + 100 + 200 >= 1000ns
// This delay is required to meet the Sharp data sheet total cycle time of > 1000ns
// @40MHz this is 2 instructions
asm nop
asm nop
inline void LCD_EnablePulseDelay()
// PWEH > 460ns on Sharp data sheet
// @40MHz this is 5 instructions
asm nop
asm nop
asm nop
asm nop
asm nop
inline void LCD_SetupDelay()
// tAS > 140ns min on Sharp data sheet
asm nop
asm nop
inline void LCD_HoldupDelay()
// tAS > 10ns min on Sharp data sheet
// @40MHz this is 1 instructions
asm nop
_LCD_TEMPL
char LCD_Read()
char d;
volatile unsigned char data@DataPort, tris@Data_PortTris;
volatile bit rw@CtrlPort.RW, e@CtrlPort.E;
if( InterfaceType == LCD_4_BIT_HI_NIB_MODE )
// upper nibble input
tris |= 0xF0;
rw = 1; // set reading mode
// first high nibble
LCD_SetupDelay();
e = 1;
LCD_EnablePulseDelay();
d = data & 0xF0; // read data
e = 0;
LCD_HoldupDelay();
LCD_CycleMakeupDelay();
// then low nibble
LCD_SetupDelay();
e = 1;
d |= data >> 4;
e = 0;
LCD_HoldupDelay();
if( InterfaceType == LCD_4_BIT_LO_NIB_MODE )
// lower nibble input
tris |= 0x0F;
LCD_SetupDelay();
e = 1;
d = data << 4;
e = 0;
LCD_HoldupDelay();
// then low nibble
LCD_SetupDelay();
e = 1;
d |= data & 0x0F;
e = 0;
LCD_HoldupDelay();
if( InterfaceType == LCD_8_BIT_MODE )
// port input
tris = 0xFF;
LCD_SetupDelay();
e = 1;
d = data;
e = 0;
LCD_HoldupDelay();
return d;
_LCD_TEMPL
void LCD_RawWriteNibble( char d )
// Note: this function is duplicate below, but declared inline.
// this is to reduce stack depth usage
// Note: this function is above, but declared inline.
// port upper nibble output
rw = 0; // set writing mode
LCD_SetupDelay();
tris &= 0x0F;
data &= 0x0F;
data |= d & 0xF0;
e = 1;
e = 0;
LCD_HoldupDelay();
LCD_SetupDelay();
tris &= 0xF0;
data &= 0xF0;
data |= d >> 4;
e = 1;
e = 0;
LCD_HoldupDelay();
_LCD_TEMPL
inline void LCD_RawWriteNibbleInline( char d )
LCD_SetupDelay();
tris &= 0x0F;
data &= 0x0F;
data |= d & 0xF0;
e = 1;
e = 0;
LCD_HoldupDelay();
LCD_SetupDelay();
tris &= 0xF0;
data &= 0xF0;
data |= d >> 4;
e = 1;
e = 0;
LCD_HoldupDelay();
_LCD_TEMPL
void LCD_RawWrite( char d )
volatile unsigned char tris@Data_PortTris, data@DataPort;
// output upper nibble, then lower nibble
bit flag = 0;
do
_LCD_RawWriteNibbleInline( d );
flag = !flag;
d <<= 4;
while( flag );
bit flag = 0;
do
flag = !flag;
d <<= 4;
while( flag );
// port b output
tris = 0x00;
data = d;
LCD_SetupDelay();
e = 1;
e = 0;
LCD_HoldupDelay();
_LCD_TEMPL
inline void LCD_WaitForNotBusy()
volatile bit rs@CtrlPort.RS; bit old_RS = rs;
rs = 0;
while( _LCD_Read() & 0x80 ); // wait while busy set
rs = old_RS;
_LCD_TEMPL
void LCD_Write(char d )
if( UseBusy == 1 )
// wait until display Not busy before sending next data
if ( writeDelayType == WriteControlled )
_LCD_WaitForNotBusy();
_LCD_RawWrite( d );
_LCD_RawWrite( d );
// give time to complete
if( !rs && (d == return_home || d == clear_lcd) )
delay_ms( 2 ); // return_home takes more time than other instructions to execute
delay_10us( 5 ); // 50us - enough time for normal command execution - clear and home need longer!!
_LCD_TEMPL
void LCD_Clear()
_LCD_FunctionMode();
_LCD_Write( clear_lcd ); // clear display
_LCD_Write( return_home );
_LCD_TEMPL
void LCD_Setup( void )
// set control port bits used to output
volatile bit trisRS@Ctrl_PortTris.RS, trisRW@Ctrl_PortTris.RW, trisE@Ctrl_PortTris.E;
trisRS = 0;
trisRW = 0;
trisE = 0;
writeDelayType = WriteNoDelay; // no delays in data writes
delay_ms(16); // Power up delay
// Reset sequence as described in data sheets
_LCD_RawWriteNibble( system_set_reset );
delay_ms(5); // min delay here of 4.1 ms
delay_10us(100); // min delay here of 100us
// LCD busy flag is valid from this point onwards
if( UseBusy == 1 )
delay_10us( 5 ); // standard command delay time
_LCD_RawWriteNibble( system_set_4_bit );
if( UseBusy == 1 )
writeDelayType = WriteControlled;
_LCD_Write( system_set_4_bit );
if( UseBusy == 1 )
if( UseBusy == 1 )
_LCD_RawWrite( system_set_reset );
delay_10us(10); // min delay here of 100us
// busy flag is valid from this point onwards
if( UseBusy == 1 )
_LCD_RawWrite( system_set_8_bit );
if( UseBusy == 1 )
writeDelayType = WriteControlled; // use busy
_LCD_Write( entry_mode );
_LCD_Write( display_on );
_LCD_Write( set_dd_ram );
_LCD_TEMPL
void LCD_Printf( const char *lcdptr )
char pi = 0, c;
_LCD_DataMode();
while( 1 )
c = lcdptr[pi++];
if ( !c )
return;
if ( c == '\n' )
// move to start second line
_LCD_Write( set_dd_ram+0x40 );
_LCD_DataMode();
_LCD_Write( c );// Display on LCD
_LCD_TEMPL
void LCD_Printf( rom char *lcdptr )
char pi = 0, c;
_LCD_DataMode();
while( 1 )
c = lcdptr[pi++];
if ( !c )
return;
if ( c == '\n' )
_LCD_Write( set_dd_ram+0x40);
_LCD_DataMode();
_LCD_TEMPL
void LCD_Printf( const char *lcdptr, unsigned int val ) // JS - Accept unsigned by default
unsigned char pi = 0, bi, c, fill, baseOrBits, sign, mask;
unsigned char buff[ 10 ]; // max length allow is 9
bit pad;
_LCD_DataMode();
while( 1 )
c = lcdptr[pi++]; if ( !c ) return;
switch( c )
case '\n':
_LCD_Write( set_dd_ram + 0x40 );
_LCD_DataMode();
case '%':
//Handle escape sequence that prints '%'
if ( c == '%' )
// Next character if zero indicates that we should zero fill output
if ( c == '0' )
fill = '0';
fill = ' ';
// Next character if valid digit indicates field width
if( c > '0' && c <= '9' )
pad = 1;
bi = c - 48;;
pad = 0;
bi = sizeof( buff ) - 1;
// Next character indicates the radix (number base)
sign = 0;
switch( c )
case 'd':
if( val & 0x8000 ) // Negative values must be adjusted to be positive // JS
sign = '-';
val ^= 0xFFFF; // 2s complement negate // JS
val++;
case 'u':
baseOrBits = 10; // base ten, divide by ten per digit
case 'X':
baseOrBits = 4; // base 16, requires a 4 bit shift per digit
mask = 0x0F;
case 'b':
baseOrBits = 1; // base 16, requires a 1 bit shift per digit
mask = 0x01;
default:
return; // no radix
// null terminate, then reverse fill string
buff[ bi ] = '\0';
bit first = true;
while( bi )
bi--;
if( val || first )
first = false;
if( baseOrBits == 10 )
c = (unsigned char)(val % 10); // JS - Optimization, use absolute of 10
val /= 10; // JS - Optimization, use absolute of 10
c = val & mask;
val = ((unsigned int)val) >> baseOrBits;
if( c > 9 )
c += 55; // convert to hex digits character A-F
c += 48; // convert to digit character 0-9
if( sign && (bi == 0 || fill != '0') )
c = sign;
sign = 0;
c = fill;
buff[ bi ] = c;
if( pad == 0 && val == 0 && sign == 0 )
// output string to display
while( 1 )
c = buff[ bi ];
if( !c ) break;
bi++;
default:
_LCD_TEMPL
void LCD_GotoXy( char x, char y )
// displays memory mapping with two lines:
// line 1: 0x00
// line 2: 0x40
// display memory mapping with four lines:
// line 1: 0x00
// line 2: 0x40
// line 3: 0x14
// line 4: 0x54
unsigned char offset = x;
if( y & 0x01 ) offset += 0x40;
if( y & 0x02 ) offset += 0x14;
_LCD_Write( set_dd_ram +0x40);
_LCD_TEMPL
void LCD_Function( char func )
_LCD_Write( func );
// Helpers that hide template arguments
// low level functions
#define lcd_write LCD_Write<LCD_ARGS>
#define lcd_waitfornotbusy LCD_WaitForNotBusy<LCD_ARGS>
#define lcd_read LCD_Read<LCD_ARGS>
#define lcd_funcmode LCD_FunctionMode<LCD_ARGS>
#define lcd_datamode LCD_DataMode<LCD_ARGS>
// high level functions - these all set function or data mode as required
#define lcd_setup LCD_Setup<LCD_ARGS>
#define lprintf LCD_Printf<LCD_ARGS>
#define lcd_clear LCD_Clear<LCD_ARGS>
#define lcd_gotoxy LCD_GotoXy<LCD_ARGS>
#define lcd_function LCD_Function<LCD_ARGS> |
oxo
Posted: Thu Feb 27, 2014 1:28 am |
How can anyone help? You don't tell us what the hardware is, you dont say what PIC, you don't say what the problem is..
It's like you going to the garage without your car, and asking them to fix it. All you tell them is that it's a ford... |
