CCS 5 problem in all codes...
Leandro
PostPosted: Wed Feb 19, 2014 9:34 am     Reply with quote
I'm trying to create a web server using the CCS 5 and this happening these errors, anyone know what's wrong?
PostPosted: Wed Feb 19, 2014 10:12 am     Reply with quote
Yes, you don't have the registers defined.
If you have the IDE, then select 'tools', 'device editor', 'registers' (right hand entry on the top bar of the window), 'make include file'. This will then create a file with all the register defines for your processor. Include this near the top of your code (after fuses processor, clock etc.).
If you don't have the IDE do a search here, include files for this have been posted in the past.
Leandro
PostPosted: Wed Feb 19, 2014 10:43 am     Reply with quote
Ttelmah thanks for help!
Is this?
Leandro
PostPosted: Thu Feb 20, 2014 12:53 pm     Reply with quote
I can not do anything with CCS5 had to remove and reinstall the version 4 release.
The problem now is that this version 4 with version 5 of the wizard, do not know what to do.
This version 5 really fumbled my life.
Leandro
PostPosted: Mon Mar 10, 2014 2:17 pm     Reply with quote
Up
Please, help me...
PostPosted: Mon Mar 10, 2014 2:26 pm     Reply with quote
Unless there is a NECESSARY reason to use V5, just go back to V4. Hopefully you've got proper backups and can do this easily.
Sometimes an 'upgrade' really isn't a good idea.
I'm still in 4.2xx something as there is NO reason for me to 'upgrade'. The features, options, etc. of v5 aren't required for my project.
hth
jay
gpsmikey
PostPosted: Mon Mar 10, 2014 4:45 pm     Reply with quote
I thought the latest version of 4 was 4.141 ?
mikey
mikey
PostPosted: Mon Mar 10, 2014 5:11 pm     Reply with quote
another slip of the finger...sigh, having a half dead finger('skil'saw won ) has been a challenge pressing keys...4.1xx
jay
PostPosted: Mon Mar 10, 2014 9:06 pm     Reply with quote
The problem now is that this version 4 with version 5 of the wizard.
You need to delete the whole CCS directory and start over with a clean
install of vs. 4.
Make sure you save your license files (*.crg) in a safe place before you
delete the CCS directory. Also make sure you save all your project files.
Save anything you don't want to lose.
gpsmikey
PostPosted: Mon Mar 10, 2014 10:16 pm     Reply with quote
jay
Yes, "skill" saws and table saws both can do some very serious damage very quickly (and I have known some very safety conscious folks that have lost an encounter with table saws).
mikey
mikey
