sam6154
Zigbee |
Posted: Mon Feb 17, 2014 1:26 am |
i haven't worked with zigbee till now hence i am in need of guidance for interfacing cc2530 and pic16f877a.
Thanks in advance. |
Joined: 01 Jul 2010 Posts: 9272 Location: Greensville,Ontario
Posted: Mon Feb 17, 2014 8:31 am |
cc2530 is a 3 volt device
16f877a is an 'old' device
do you have a cc2530 chip or premade module?
If module, post link to datasheet
If chip, I'm out as it's a very,very complicated SMT device needing a LOT of very,very careful PCB layout and connections.
Zigbee ,if run in AT(aka 'transparent') mode , is easy,but slow.
hth
jay |
Zloi
Re: Zigbee |
Posted: Mon Feb 17, 2014 12:44 pm |
sam6154 wrote: | i haven't worked with zigbee till now hence i am in need of guidance for interfacing cc2530 and pic16f877a.
Read the "CC2530ZNP Interface Specification.pdf", as mentioned keep an eye on voltage levels.
You need to to load cc2530 module with TI ZNP firmware (ZNP zigbee network processor), then decide on interface you are going to use to communicate with PIC mcu, (UART or SPI) and finaly,
write your own C PIC drivers.
I worked with SPI interface, here is code snippet.
void ZNP_Sys_Version(void){
for(i=0;i<=ZNP_Data_Array_Size;i++){
Data[i]=0;
printf(bputc,"PIC -> ZNP System verzion information\n\r");
ZNP_Write[0]=0x00;
ZNP_Write[1]=0x21;
ZNP_Write[2]=0x02;
ZNP_Send_Command(ZNP_Write,3);
void ZNP_Clear_Device(void){
Data[i]=0;
printf(bputc,"PIC -> ZNP Clear Device on Reset\n\r");
ZNP_Write[0]=0x03;
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x05;
ZNP_Write[3]=0x03;
ZNP_Write[4]=0x01;
ZNP_Write[5]=0x03; //Clear device on reset
ZNP_Send_Command(ZNP_Write,6);
void ZNP_Write_Logical_Type(unsigned int8 type){
Data[i]=0;
if(type==0x00){
printf(bputc,"PIC -> ZNP logical type Coordinator\n\r");
}else if(type==0x01){
printf(bputc,"PIC -> ZNP logical type Router\n\r");
}else if(type==0x02){
printf(bputc,"PIC -> ZNP logical type End Device\n\r");
ZNP_Write[0]=0x03;
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x05;
ZNP_Write[3]=0x87;
ZNP_Write[4]=0x01;
ZNP_Write[5]=type;
void ZNP_Write_PAN_ID(unsigned int8 b1,unsigned int8 b2){
Data[i]=0;
printf(bputc,"PIC -> ZNP Write Pan ID %X%X\n\r",b1,b2);
ZNP_Write[0]=0x04;
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x05;
ZNP_Write[3]=0x83;
ZNP_Write[4]=0x02;
ZNP_Write[5]=b1;
ZNP_Write[6]=b2;
ZNP_Send_Command(ZNP_Write,7);
void ZNP_Write_Channel(unsigned int8 b1,unsigned int8 b2,unsigned int8 b3,unsigned int8 b4 ){
Data[i]=0;
printf(bputc,"PIC -> ZNP Write Channel %X%X%X%X\n\r",b4,b3,b2,b1);
ZNP_Write[0]=0x06;
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x05;
ZNP_Write[3]=0x84;
ZNP_Write[4]=0x04;
ZNP_Write[5]=b1; //Clear device on reset
ZNP_Write[6]=b2;
ZNP_Write[7]=b3;
ZNP_Write[8]=b4;
ZNP_Send_Command(ZNP_Write,9);
void ZNP_Soft_Reset(void){
Data[i]=0;
printf(bputc,"PIC -> ZNP Device Soft Reset\n\r");
ZNP_Write[0]=0x01;
ZNP_Write[1]=0x41;
ZNP_Write[2]=0x00;
ZNP_Write[3]=0x00;
ZNP_Send_AREQ(ZNP_Write,4);
void ZNP_ZB_APP_Register(void){
Data[i]=0;
printf(bputc,"PIC -> ZNP APP Register\n\r");
ZNP_Write[0]=0x0D;
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x0A;
ZNP_Write[3]=0x01; //App end point
ZNP_Write[4]=0x01; //App profile ID0
ZNP_Write[5]=0x01; //App profile ID1
ZNP_Write[6]=0X01; //Device id0
ZNP_Write[7]=0x01; //devide id1
ZNP_Write[8]=0x00; //device verzion
ZNP_Write[9]=0x00; // unused
ZNP_Write[10]=0x01; //input comands num
ZNP_Write[11]=0x00; // input comands list 0
ZNP_Write[12]=0x01; // input comands list 1
ZNP_Write[13]=0x01; // output comands num
ZNP_Write[14]=0x00; //output comands list 0
ZNP_Write[15]=0X01; // output comands list 1
ZNP_Send_Command(ZNP_Write,16);
void ZNP_ZB_Start_Request(void){
Data[i]=0;
printf(bputc,"PIC -> ZNP Start Request\n\r");
ZNP_Write[0]=0x00;
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x00;
void ZNP_Set_Tx_Power(unsigned int8 b1){
Data[i]=0;
printf(bputc,"PIC -> ZNP Set Tx Power\n\r");
ZNP_Write[0]=0x01;
ZNP_Write[1]=0x21;
ZNP_Write[2]=0x14;
ZNP_Write[3]=b1; //set tx power to 20dBm
ZNP_Send_Command(ZNP_Write,4);
void ZNP_Get_Device_IEEE(void){
Data[i]=0;
printf(bputc,"PIC -> ZNP Get_Device_IEEE\n\r");
ZNP_Write[0]=0x01;
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x06;
ZNP_Write[3]=0x01; //set tx power to 20dBm
void ZNP_Get_Device_Info(void){
Data[i]=0;
printf(bputc,"PIC -> ZNP Get_Device_Info\n\r");
ZNP_Write[0]=0x01;
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x06;
ZNP_Write[3]=0x00; //set tx power to 20dBm
void Bord_Data(char *str,unsigned int8 len){
Data[i]=0;
unsigned int8 k=1;
printf(bputc,"du?ina = %d\n\r",len);
printf(bputc,"PC -> BoarData\n\r");
ZNP_Write[1]=0x26;
ZNP_Write[2]=0x03;
ZNP_Write[3]=0xFC; //destination id0
ZNP_Write[4]=0xFF; //destination id1
ZNP_Write[5]=0x00; //command id0
ZNP_Write[6]=0x00; //command id1
ZNP_Write[7]=0x00; //handle
ZNP_Write[8]=0x00; //ack
ZNP_Write[9]=0x03; //radius
ZNP_Write[10]=len; //len of data
while(len--){ //znp se javio, po?alji mu podatak
ZNP_Write[10+k]=*str++;
k++;
k=1;
ZNP_Write[0]=ZNP_Write[10]+8; //Data dio plus fiksni dio
for(k=0;k<=ZNP_Write[0]+2;k++){
printf(bputc,"%X",ZNP_Write[k]);
printf(bputc,"\n\r");
//ZNP_Send_Command(ZNP_Write,16);
void ZNP_Send_Command(char *pMsg, unsigned int8 len){
output_low(MRDY_ZNP); //Select ZNP
while(input(SRDY_ZNP)){
} //Cekaj Da se znp javi
spi_write(*pMsg++);
while(!input(SRDY_ZNP)){
// delay_cycles (2);
Data[0]=spi_read(0);
Data[1]=spi_read(0);
Data[2]=spi_read(0);
for(i=0;i<=Data[0];i++){
Data[i+3]=spi_read(0);
ZNP_SetDataReady();
output_high(MRDY_ZNP); //DeSelect ZNP
void ZNP_Send_AREQ(char *pMsg, unsigned int8 len){
while(input(SRDY_ZNP)){}; //Cekaj Da se znp javi
spi_write(*pMsg++);
while(!input(SRDY_ZNP)){};
