zombiePIC
Switch statement using push button increment to switch cases |
Posted: Sun Feb 16, 2014 3:32 pm |
Hi Guys
I am trying to set up a LED lighting system that can demo through different opperating modes. For example I want the LED to ramp up to full brightness then push a button and ramp down to low brightness then push the button again and return to full brightness and so on.
I think I am having trouble with the PWM set up.....
for case 1 I get full brightness no ramp up
for case 2 I get probally less than 5% brightness with no ramp down ..
PIC16F87
IDE version 5.016
PCB version 5.016
PCM version 5.016
PCH version 5.016
ICD-U64
CCS LOAD V4.051
Windows 8.1 64 bit
Can some body have a look at my code
Code: | #include <16F87.h>
#fuses INTRC,NOWDT
#use delay(clock=1000000)
#define Button_Press PIN_A0
int count=0;
void demo_sequence(int Demo_Number){
// variables used to set by PWM duty cycle
long led_duty =0;
int led_set=0;
// PWM Setup
setup_oscillator(OSC_1MHZ);
setup_ccp1(CCP_PWM);
setup_timer_2(T2_DIV_BY_4, 64, 1);
switch(Demo_Number){
case 0 : led_set=255;//Demo 0 while count zero, set LED to full brightness
if(led_duty<led_set){led_duty++;}
if(led_duty>led_set){led_duty--;}
set_pwm1_duty(led_duty);//ramp up to 255, full brightness
delay_ms(10);
case 1 : led_set=51;//Demo 1 while count 1, set LED to 20%
set_pwm1_duty(led_duty);//ramp down to 20%
delay_ms(10);
count=0;//return to start
void wait_for_one_press(){
while(input(Button_Press));
while(!input(Button_Press));
while (TRUE){
wait_for_one_press();
count++;
demo_sequence(count);
I have no scope to measure the PWM
Thanks |
stinky
Joined: 05 Mar 2012 Posts: 99 Location: Central Illinois
Posted: Sun Feb 16, 2014 4:51 pm |
What happens if the button isn't being pressed? |
Joined: 01 Jul 2010 Posts: 9177 Location: Greensville,Ontario
Posted: Sun Feb 16, 2014 5:16 pm |
keyword is 'debounce'.
search the forum using it, read a few posts.
hth
jay |
zombiePIC
Posted: Sun Feb 16, 2014 5:17 pm |
Quote: | What happens if the button isn't being pressed? |
I persume the code jumps to the case statement depending on the count value... looks like that anyway.. |
zombiePIC
Posted: Sun Feb 16, 2014 5:26 pm |
Quote: | keyword is 'debounce'.
search the forum using it, read a few posts. |
I will give that a try... but i think i will be back here.. |
zombiePIC
Posted: Sun Feb 16, 2014 5:49 pm |
Hi
I modified my code to include the comment made in this thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=51914&highlight=debounce+increment
#fuses INTRC,NOWDT
#define LOW 0
#define HIGH 1
int count=0;
long led_duty =0;
int led_set=0;
// PWM Setup
case 0 :
break;}
case 1 :
break;}
if (input(Button_Press)==LOW)
delay_ms(10); //short delay
if (input(Button_Press)==LOW) //key is still low
count++;
while (TRUE){
Added a while loop to the case statement...
No change. the LED stays at full brightness after PB is incremented.... Quote: | keyword is 'debounce'.
Mike Walne
Posted: Sun Feb 16, 2014 5:54 pm |
Two additional comments:-
1) Case statements look too complex.
2) For loops (or while loops) in case statements may achieve what you're after.
Mike |
Posted: Mon Feb 17, 2014 1:43 am |
Just re-typed the code to show a major problem.....
case 0 :
while (count==0)
led_duty++;
led_duty--;
delay_ms(10);
Now read up on what 'break' does.
A break exits the _innermost_ control loop (for, while, do, switch).
So this code executes _once_ (good thing since nothing will ever change count in this), then runs off the end of the case (since there is no 'break' for this).
The flow is fundamentally flawed. |
zombiePIC
Posted: Mon Feb 17, 2014 11:30 am |
I am having no success here, i played around with the break; no joy.....I dont seem to understand what could be wrong now.. |
ezflyr
Posted: Mon Feb 17, 2014 11:36 am |
Pssst...... Your 'Break' statement is inside your 'While' loop, so the loop runs once and exits. You want to move the 'Break' outside of the 'While' loop so
as to exit the 'Case 0' section instead......
You might find some relevant 'C' language programming help here: https://docs.google.com/file/d/0B_EYtdS7J5eKZ1RaeEt4a2hlQnM/edit?pli=1
John |
Posted: Mon Feb 17, 2014 11:44 am |
break your code up( no pun intended).
Start with a simpler program where each case statement sends a printf(....case number...) to PC or LCD module.This way you can easily debug and see what's going on since case '3' should send the number '3' to the PC.
hth
jay |
zombiePIC
Posted: Mon Feb 17, 2014 11:50 am |
No luck modified the code to change break;
#fuses INTRC,NOWDT
#define LOW 0
#define HIGH 1
int count=0;
long led_duty =0;
int led_set=0;
// PWM Setup
case 0 :
while (count==0)
led_duty++;
led_duty--;
delay_ms(10);
case 1 :
while (count==1)
led_set=55;//Demo 0 while count zero, set LED to full brightness
led_duty++;
led_duty--;
delay_ms(10);
while (TRUE){
When target board starts up the LED ramps from low to high. No change occurs when button is pressed several times.
Code: | void wait_for_one_press(){
this bit of code was taken from the Exercise book for the ccs 16f877a dev board |
Mike Walne
Posted: Mon Feb 17, 2014 11:51 am |
The switch case is not now your real problem.
You've fouled up another section as well.
So, you never actually get to the break as a problem!
How do you imagine that this latest posted version ever exits?
count++;
Mike |
zombiePIC
Posted: Mon Feb 17, 2014 11:53 am |
How do you imagine that this latest posted version ever exits? |
i switched back over to this....
Code: | Code:
gpsmikey
Posted: Mon Feb 17, 2014 12:08 pm |
All waiting for button press to go true then false does is go through there many times when the switch bounces (which most of them do). Switch bounces have driven many people screaming into the night - you either need to debounce it in software or hardware (something like an RC network can work well although it introduces a slight delay in sensing switch closure). Multiple closures in just a few ms (typical) causes most software to act goofy and the user does not realize that they have effectively pushed the button multiple times in just a few ms. Just for entertainment, you could create a little routine that used your "check for low, check for high" routine and increments a counter each time through then displays the result (count switch bounces) and see what it shows each time you press the switch. Would be interesting to see how many times it bounces.
mikey _________________ mikey
