Failed to load cof file / stacksize?
MeisterOss
PostPosted: Thu Feb 13, 2014 3:12 am     Reply with quote
Hello
I already found some topics with that title, but non of these helped me by solving my problem.
I change form CCS 4.137 to CCS 5. 018 . I´m using MPLAB IDEv8.92 and PIC24HJ256GP610.
After a successful build of the project a pop up window appears with the message: Failed to load .../filepath/filename.cof
I already changed the Build Option to Debug = none instead of Debug = COFF format, but this makes no difference.
I also checked the STA File of the project and the Stack is at 100% (30/30, Interrupts=0). My privious build with CCS 4.137 has only 9/30.
I`m not sure if these issues depend on each other but I`m very happy about any advice or tip to solve the problems.
Thank you
PostPosted: Thu Feb 13, 2014 4:48 am     Reply with quote
On the stacksize, the newer compiler makes no attempt to reduce this, until it has to. It will fill the stack up on the basis that code is smaller. However the STA reports seem also to be 'wrong' at times. Have had code reporting ROM use at 170% in the STA reports. Tend to just look at the .LST file, whose figures seem to be right....
MeisterOss
PostPosted: Thu Feb 13, 2014 7:57 am     Reply with quote
Ok thanks Ttelmah.
I solved the problem by updating the compiler to V5.019
May be this was the reason:
RECENT CHANGES
5.019 A problem with addressmod for some chips and data types is fixed
MeisterOss
PostPosted: Thu Feb 13, 2014 7:59 am     Reply with quote
By the way CCS V5.016 works too Confused
PostPosted: Thu Feb 13, 2014 8:36 am     Reply with quote
Are you using Addressmod?.
It'll be nice if this starts working. It is one of those "hasn't been working for several versions" features, that I miss.... Smile
jeremiah
PostPosted: Thu Feb 13, 2014 11:28 am     Reply with quote
I sent CCS an email about address mod a month ago. The reply said they had fixed it in the latest version. I haven't had a way to test it out just yet.
