CCS C Compiler ide error
andrearm73
PostPosted: Tue Feb 11, 2014 4:30 am     Reply with quote
Hello, I would need a help with an error in the development environment I have, I'm changing the code done by a colleague of mine, I open the file. C, compile it, I get errors, correct them, but when I try to save the file I get the error: "I can not open the file is open by another process"
I am forced to close the IDE without losing save the changes.
Do you have suggestions?
Thanks in advance Confused
dyeatman
PostPosted: Tue Feb 11, 2014 7:05 am     Reply with quote
Are you working on a network drive?
Google and Forum Search are some of your best tools!!!!
newguy
PostPosted: Tue Feb 11, 2014 9:10 am     Reply with quote
Used to have a similar problem which was caused by a slow backup drive and its associated backup software. I'd create a change, compile, and the CCS IDE would pop up an error that a file couldn't be created.
andrearm73
PostPosted: Tue Feb 11, 2014 9:20 am     Reply with quote
hello,
I'm not working on my hd but I solved by using another editor, correcting some problems compiling the code and started back to work properly .. I have no idea what happened: (
thanks for the answers Shocked Shocked Shocked
