SOLVED: Strange PWM behaviour
alan
PostPosted: Sat Feb 08, 2014 6:38 am     Reply with quote
Hi All
dsPIC33EP64GP506
5.017
I set up the PWM to run 50kHz 10% dutycycle, all work OK. PWM 50kHz with 10% duty.
However it only run for 7.5ms then output are low for 7.5ms and then repeat this pattern.
Any idea? Confused
#include <33EP64GP506.h>
#FUSES OSCIO                    //OSC2 is general purpose output
#FUSES NOCKSNOFSM               //Clock Switching is disabled, fail Safe clock monitor is disabled
#FUSES NOIESO                   //Internal External Switch Over mode disabled
#define CLK_FREQ 20000000
#use delay(internal=CLK_FREQ)
#include <stdint.h>
#define LED_GREEN PIN_A8
#define LED_RED PIN_D6
//Setup PWM Boost for Display
#use PWM(PWM1,OUTPUT=PIN_G6,TIMER=3,FREQUENCY=50KHz,DUTY=10,STREAM=DISPPWM)
uint16_t LEDTime;
#INT_TIMER1
void  timer1_isr(void) {
   if (LEDTime++ > 500) {
    LEDTime = 0;
    output_toggle(LED_RED);
  setup_timer1(TMR_INTERNAL | TMR_DIV_BY_1, 10000); //2ms Timer
  while(TRUE) {
Regards
PostPosted: Sat Feb 08, 2014 7:03 am     Reply with quote
hmm..my first thought was that the WDT is enabled, but fuse say nowdt....
maybe a 'brownout' fuse is enabled and Vcc < threshold ?
the 7.5ms rate seems too 'nice'.
I know you don't want to 'step back' but I'd try the '1Hz flashing LED' program with NO ISRs and see what happens.
hth
jay
alan
PostPosted: Sat Feb 08, 2014 7:14 am     Reply with quote
Thanks Jay for feed back
1Hz work fine with no interrupts. I also added a delay of 2 sec on start-up to see check whether it is not a restart. Get the delay on startup and then 1Hz on LED.
What I did notice, that sometimes after a reprogram it seems to be about 14ms instead of the 7ms, but when I cycle power it is back on the approx 7.5ms, actually it varies from 7.4 to say 7.7ms.
Regards
Alan
PostPosted: Sat Feb 08, 2014 7:35 am     Reply with quote
rats, so much for the 'easy' stuff!
If using MPLAB, any chance you're compiling in 'debug' mode and not 'release'?
That can cause 'odd' things to happen....
jay
alan
PostPosted: Sat Feb 08, 2014 7:40 am     Reply with quote
Just to be sure, I disconnect the programmer after programming and the issue are still the same.
Regards
PS I have to use MPLAB and ICD3 as CCS are still beta for this chip.
alan
PostPosted: Sat Feb 08, 2014 7:42 am     Reply with quote
Maybe I should just mentioned that Pin 3 and 4 are tied together, I do not see an issue with this, but just MAYBE Surprised
Regards
PostPosted: Sat Feb 08, 2014 7:58 am     Reply with quote
hmm..I don't use them 'fancy PICs', but perhaps there's a peripheral that needs to be disabled also don't know what's on pins 3 or 4....
hth
jay
alan
PostPosted: Sat Feb 08, 2014 8:12 am     Reply with quote
On Pin 3: RPI47/T5CK/RB15
On Pin 4: RP118/RG6
Anyway I cut the tracks, no difference. Crying or Very sad
Regards
alan
PostPosted: Sat Feb 08, 2014 9:44 am     Reply with quote
OK manage to get it working by writing directly to the registers.
Could not use the setup_compare function as the PWM does not use the TIMERS on this specific chip. And the USE PWM also want to specify a TIMER
by just adding the following it worked like a charm.
#WORD OC1RS = getenv("SFR:OC1RS")
#WORD OC1CON1 = getenv("SFR:OC1CON1")
#WORD OC1CON2 = getenv("SFR:OC1CON2")
OC1CON1 = 0x1c06;
OC1CON2 = 0x001f;
OC1RS = 200; //Period: 50kHz = 1/50e3 * 1/Tcy
set_pwm_duty(1,20); //10% DutyCycle
Also although the datasheet specify that 0x1f are the same as 0x00 when specifying the SYNCSEL bits it does not work on 0x00.
Regards
PostPosted: Sat Feb 08, 2014 10:36 am     Reply with quote
hmm.. well I'm glad someone is winning today !!!!
sounds like a compiler 'bug', easier to deal with tahn -19*C weather I'm in !!
cheers
jay
alan
PostPosted: Sat Feb 08, 2014 11:05 am     Reply with quote
Nice 28*C here.
Anyway here are an update involving less register manipulation.
    setup_compare(1, COMPARE_SYSTEM_CLOCK | COMPARE_PWM_EDGE );
    set_compare_time(1,20,200); //PWM no, Duty, Period
    OC1CON2 = 0x001f; //Datasheet fault
Regards
Alan
arocholl
PostPosted: Thu Apr 03, 2014 4:38 pm     Reply with quote
Hi Alan, do you mind adding the full code you ended up with? I am not sure to realize what you left and what you remove from the original post. I am having some trouble to get a DSPIC33EP to work with PWM.
thanks in advance.
alan
PostPosted: Fri Apr 04, 2014 3:31 am     Reply with quote
I do not understand. That is the full code to get the PWM working. Do not use the #use PWM directive from CCS.
Are your PIC running the 1Hz LED test successfully?
Regards
Alan
