LCD Graphic Display
CleberIzidoro
LCD Graphic Display
PostPosted: Fri Feb 07, 2014 12:44 pm     Reply with quote
I'm working on a project with an LCD Winstar WG240128A and the T6963 driver, with this display and this driver works correctly. When using a WG240128B display, the display does not work and hangs PIC. Is there any relation with the T6963 and the RA6963 driver?
PostPosted: Fri Feb 07, 2014 1:38 pm     Reply with quote
If check with Google, they are supposed to be compatible.
Assuming that is true, the next thing is to carefully check your wiring.
