Modbus TCP multiple node communication*** Locked - off topic
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
asd
PostPosted: Thu Feb 06, 2014 8:15 pm     Reply with quote
Locked.
Reason: Visual C++ is off-topic on CCS C compiler for Microchip PIC
microcontrollers forum.
- Forum Moderator
I'm working on win ce 6 modbus tcp client server, application is developed for a client server communication and it is working fine. Now requirement is my slave device should respond to the different slave addresses polled by master/client. Can I just change slave id and establish connection or I need to close previous connection and again establish new one ?
Below is the code, which is working fine for one node. If I polled with other node ID then it gives exception. What change is required to communicate with other node simultaneously ? My device should be able to communicate with 32 different nodes on modbus tcp. Shall I create individual threads for each node ? But how will they communicate on same port? Before establishing connection with other node shall I close previous node?
startupServer(int slaveAddr,  const TCHAR * const hostName)
   int result;
   int tcpOption;
   struct sockaddr_in hostAddress;
   if (isStarted())
      return (FTALK_ILLEGAL_STATE_ERROR);
   // Note: For TCP we allow 0 as slave address, -1 means ignore slave adr
   if ((slaveAddr < -1) || (slaveAddr > 255))
      return (FTALK_ILLEGAL_ARGUMENT_ERROR);
   this->slaveAddr = slaveAddr;
   // Special treatment for the Win32 platform, needs to load WinSock DLL
#ifdef _WINSOCKAPI_
   WSADATA wsaData;
   result = WSAStartup(0x0101, &wsaData);
   if (result != 0)
      return (FTALK_SOCKET_LIB_ERROR);
#endif
   // Open socket
   listenSocket = socket(PF_INET, SOCK_STREAM, 0);
   if (listenSocket == INVALID_SOCKET)
      shutdownServer();
      return (FTALK_OPEN_ERR);
   // Configure listen socket options (we ignore errors here)
#ifdef SO_REUSEADDR
   tcpOption = 1; // Enable option
   setsockopt(listenSocket, SOL_SOCKET, SO_REUSEADDR,
              (char *) &tcpOption, sizeof (tcpOption));
#endif
   // Binding the listen socket to the port
   hostAddress.sin_family = AF_INET;
   if ((hostName == NULL) || (hostName[0] == '\0'))
      hostAddress.sin_addr.s_addr = htonl(INADDR_ANY);
      hostAddress.sin_addr.s_addr = inet_addr((char *) hostName);
#if !defined(__VXWORKS__) // We don't support host name resolving with VxWorks
      if (hostAddress.sin_addr.s_addr == INADDR_NONE)
         struct hostent *hostInfo;
         hostInfo = gethostbyname((char *) hostName);
         if (hostInfo == NULL)
            return (FTALK_TCPIP_CONNECT_ERR);
         hostAddress.sin_addr = *(struct in_addr *) hostInfo->h_addr;
#endif
   hostAddress.sin_port = htons(portNo);
   result = bind(listenSocket, (struct sockaddr *) &hostAddress,
                 sizeof (hostAddress));
   if (result == SOCKET_ERROR)
      shutdownServer();
      switch (socketErrno)
#ifdef _WINSOCKAPI_
         case WSAEACCES:
         return (FTALK_PORT_NO_ACCESS);
         case WSAEADDRINUSE:
         return (FTALK_PORT_ALREADY_BOUND);
         case WSAEADDRNOTAVAIL:
         default:
         return (FTALK_PORT_NOT_AVAIL);
#else
         case ENOTCONN: // Linux 7.2 reports this error no if no root privilege
         case EACCES:
         case EADDRINUSE:
         case EADDRNOTAVAIL:
         default:
#endif
   // Start listening to incoming connections
   result = listen(listenSocket,
               ((MAX_CONNECTIONS < SOMAXCONN) ? MAX_CONNECTIONS : SOMAXCONN));
      shutdownServer();
      return (FTALK_LISTEN_FAILED);
   return (FTALK_SUCCESS);
serverLoop()
   int iReturnCode = (FTALK_SUCCESS);
   int result;
   int sockIdx;
   int recvResult;
   int sendResult;
   fd_set fdSet;
   timeval timeVal;
   SOCKET maxFileDes;
   int replyCnt;
   int tcpOption;
   if (!isStarted())
   // Prepare file descriptor set for select call
   FD_ZERO (&fdSet);
#ifdef _MSC_VER
#  pragma warning(push)
#  pragma warning(disable: 4127)
#endif
   FD_SET (listenSocket, &fdSet);
#ifdef _MSC_VER
#  pragma warning(pop)
#endif
   maxFileDes = listenSocket;
   for (sockIdx = 0; sockIdx < MAX_CONNECTIONS; sockIdx++)
      if (connectionSocketArr[sockIdx] != INVALID_SOCKET)
#ifdef _MSC_VER
#endif
         FD_SET (connectionSocketArr[sockIdx], &fdSet);
#ifdef _MSC_VER
#endif
      if (connectionSocketArr[sockIdx] > maxFileDes)
         maxFileDes = connectionSocketArr[sockIdx];
   // Block until accept request or received data or time-out
   timeVal.tv_sec = (long) timeOut / 1000L;
   timeVal.tv_usec = ((long) timeOut % 1000L) * 1000L;
   if (timeOut == 0)
      result = select((int) maxFileDes + 1, &fdSet, NULL, NULL, NULL);
      result = select((int) maxFileDes + 1, &fdSet, NULL, NULL, &timeVal);
      return (FTALK_FILEDES_EXCEEDED);
   // Check for time-out
   if (result == 0)
      TRACELOG1("Slave poll time-out!\n");
      dataTablePtr->timeOutHandler();
      iReturnCode = (FTALK_REPLY_TIMEOUT_ERROR);
   // Connection accept request
   if (FD_ISSET (listenSocket, &fdSet))
      // Search a free socket
         if (connectionSocketArr[sockIdx] == INVALID_SOCKET)
            struct sockaddr_in peerAddr;
            SOCK_LEN_TYPE peerAddrLen = sizeof(peerAddr);
            // Yes, socket is free, try to accept a connection on it
            connectionSocketArr[sockIdx] = accept(listenSocket,
                                                  (struct sockaddr *) &peerAddr,
                                                  &peerAddrLen);
               // Check id connection shall be accepted
               if (!dataTablePtr->validateMasterIpAddr(inet_ntoa(peerAddr.sin_addr)))
                  shutdown(connectionSocketArr[sockIdx], SD_BOTH);
                  closesocket(connectionSocketArr[sockIdx]);
                  connectionSocketArr[sockIdx] = INVALID_SOCKET;
                  TRACELOG2("Connection rejected on slot %d\n", sockIdx);
               // Set socket options (we ignore errors here, not critical)
#ifdef TCP_NODELAY
               setsockopt(connectionSocketArr[sockIdx],
                          IPPROTO_TCP, TCP_NODELAY,
#endif
#ifdef SO_SNDBUF
               tcpOption = MAX_MSG_SIZE;
                          SOL_SOCKET, SO_SNDBUF,
#endif
#ifdef SO_RCVBUF
                          SOL_SOCKET, SO_RCVBUF,
#endif
#ifdef SO_LINGER
               tcpOption = 0; // Disable option = discard unsent data when closing
                          SOL_SOCKET, SO_LINGER,
#endif
               TRACELOG2("Connection accepted on slot %d\n", sockIdx);
            break; // Leave for loop
   // Data received on socket
         if (FD_ISSET (connectionSocketArr[sockIdx], &fdSet))
            recvResult = recv (connectionSocketArr[sockIdx],
                               (char *) bufferArr, sizeof (bufferArr), 0);
            sendResult = 0;
            replyCnt = 0;
            // Process client message
            if (recvResult >= PREFIX_LEN) // Process only minimum message sizes
               short dataLen;
               dataLen = (short) ((bufferArr[4] << 8) | (bufferArr[5] & 0xFF));
               // Validate length before processing message
               if ((dataLen + PREFIX_LEN) == recvResult)
                  replyCnt = processMessage(&bufferArr[PREFIX_LEN],
                                            recvResult - PREFIX_LEN);
                  // The first two bytes (msg id) are returned untouched
                  bufferArr[2] = 0; // protocol identifier
                  bufferArr[3] = 0; // protocol identifier
                  bufferArr[4] = (char) ((replyCnt) >> 8);
                  bufferArr[5] = (char) ((replyCnt) & 0xFF);
                  sendResult = send(connectionSocketArr[sockIdx],
                                    (char *) bufferArr,
                                    replyCnt + PREFIX_LEN, 0);
            // Check for disconnection and errors
            if ((recvResult < PREFIX_LEN) ||
                (sendResult != replyCnt + PREFIX_LEN))
               // Free socket
               if (recvResult == 0)
                  TRACELOG2("Disconnected slot %d nicely by other peer.\n",
                            sockIdx);
                  TRACELOG2("Forced disconnection on slot %d!\n", sockIdx);
   return iReturnCode;
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
