PIC18F45K22 ADC Problem
mryldz
PostPosted: Wed Feb 05, 2014 9:29 am     Reply with quote
Hi everyone,
I've a small question, I only need a working code for ADC and it has to be like these type. I write these codes, but it doesn't work on circuit. So, where is the mistake in these codes given below. Maybe it is about "fuses" ?
#include <18F45K22.h>
#device ADC=8
#fuses XT,INTRC_IO,NOWDT,PUT,BROWNOUT,NOLVP
#define LED PIN_B2
#define LED1 PIN_B0
#define LED2 PIN_B4
unsigned long int g;
float fb;
setup_adc(adc_clock_div_32);
setup_adc_ports(ALL_ANALOG);
   enable_interrupts(INT_AD);
set_adc_channel(1);
delay_ms(20);
g=read_adc();
fb=1+(0.001953125*g);
  if (fb>0)
    output_high(LED);
  output_low(LED);
PostPosted: Wed Feb 05, 2014 10:19 am     Reply with quote
First, you must only enable one oscillator.
Currently you have 'XT', which says to use an external crystal, and
'INTRC_IO' which says to use the internal oscillator, and enable I/O on external oscillator pins.
Then you must _never_ enable an interrupt without a handler. You don't want INT_AD enabled. This is only used when you are using a hardware event to enable the ADC (CCP for example), which you are not doing, and enabling it without a handler will crash the code when the ADC completes.
Then you have the ADC set to only return 8 bits. (ADC=8)....
Then don't use floats. Seriously, either use ADC counts, or convert to a scaled integer. Float maths should be avoided unless it is completely necessary. It is bulky, and slow.
As written, it is always going to be >0. ADC values are always positive, and you are adding '1', so the value is going to be 1, 1.00193 etc.. Never -ve.
Then you should only select the ADC channel once, outside the loop.
gpsmikey
PostPosted: Wed Feb 05, 2014 10:20 am     Reply with quote
Well, without my morning coffee yet, the first thing that I see is how would "fb" ever be less than 1? You are adding some unsigned number times a positive coefficient to 1. That will always give you "1+something". Since you don't say exactly what "doesn't work on circuit" means, that is the first thing I notice. Since you are testing for "fb>0" that will always be true.
mikey
mikey
