problem with switch case statements
josue
PostPosted: Mon Feb 03, 2014 9:19 pm     Reply with quote
Hi everybody.. Im trying to do a switch case statement but the compiler throws an error...
*** Error 117 "probando_uart.c" Line 142(1,2): Improper use of a function identifier
*** Error 51 "probando_uart.c" Line 144(1,5): A numeric expression must appear here
*** Error 51 "probando_uart.c" Line 167(1,5): A numeric expression must appear here
this is my code
#include <16F877A.h>
#fuses XT, NOWDT, NOPROTECT, NOLVP
#use rs232(UART1, baud=9600)
#define LED_ON(x) output_high(x)
#define LED_OFF(x) output_low(x)
#define ledR PIN_B1
#define ledV PIN_B0
short correcto=FALSE; //indica resultado de la suma de control
BYTE recepcionXbee[50]; //almacenamiento de las recepciones
BYTE auxRecepXbee[100]; //auxiliar para el almacenamiento de las recepciones
BYTE sumaDeControl=0;
BYTE prx=0;
int i= 0;
int a= 0;
int cuenta;
BYTE bit64dir0;
BYTE bit64dir1 ;
BYTE bit64dir2 ;
BYTE bit64dir3;
BYTE ruta= 0x00;
BYTE board;
BYTE data_out;
BYTE dimmer;
BYTE dimmer1;
BYTE tv;
BYTE checksum;
BYTE bit4_64dir;
BYTE bit5_64dir;
BYTE bit6_64dir;
BYTE bitLsb64dir ;
BYTE bitMsb16dir ;
BYTE bitLsb16dir ;
// Direccion de envio XBEE
//7E 00 12 10 01 00 13 A2 00 40 A1 21 F8 CB 97 00 00 48 4F 4C 41 9B
#define startbit 0X7E
#define tamamin 0x00
#define tamamax 0x14
#define frametype 0x10 // trasminsion
#define frametype1 0x90 // recepcion
#define frameid 0x01
#define bitMsb64dir 0x00
#define bit1_64dir 0x13
#define bit2_64dir 0xA2
#define bit3_64dir 0x00
#define broadcast_radius 0x00
#define options 0x00
#define EDR11 0x02
#define EDR12 0x02
#define EDR13 0X03
#define EDR21 0X05
#define EDR22 0X05
#define EDR23 0X06
#define EDR31 0X08
#define EDR32 0X09
#define EDR33 0X0A
#define EDR34 0X0B
// Limpio la variable AUX RECEP
void limpiarAuxRecep(void)
 int t=0;
 do{auxRecepXbee[t++]=0;}
while(t<=99);
// Limpio la variable RECEP
void limpiarRecepcion()
 int t=0;
do {recepcionXbee[t++]=0;}while(t<=49);
 i=0;
// paso valores de recepcionXbee a AuxrecepcionXBEE
void pasar_auxRecepcionXbee(){
if(recepcionXbee[0] != 0){
for( a = 0; a<= i; a++){
auxRecepXbee[a] = recepcionXbee[a];
limpiarRecepcion();
// asses data
void digiero_data(){
if((auxRecepXbee[0]== startbit)&& (auxRecepXbee[1]== tamamin) && (auxRecepXbee[2] == 0x12) && (auxRecepXbee[3]== frametype1)){
            bit64dir0 = auxRecepXbee[8];
            bit64dir1 =auxRecepXbee[9];
            bit64dir2 =  auxRecepXbee[10];
            bit64dir3 =auxRecepXbee[11];
            ruta =auxRecepXbee[15];
            board =auxRecepXbee[16];
            data_out =auxRecepXbee[17];
            dimmer =auxRecepXbee[18];
            dimmer1 =auxRecepXbee[19];
            tv =auxRecepXbee[20];
//  veo hacia donde transmito
void donde_transmitir(){
switch(ruta){
case EDR11:
if(board == 0x09){
bit4_64dir= 0xFF; /////////////////////////
bit5_64dir=0xFF;  //  Direccion baja de 64 bits del Xbee  asociado a la board 0x09 "EDR1-D1"
bit6_64dir=0xFF;  //
bitLsb64dir=0xFF; ////////////////////////
bitMsb16dir=0xFF;   //
bitLsb16dir=0xFF;   //Direccion de 16bits del Xbee  asociado a la board 0x09 "EDR1-D1"
checksum = 0xFF - (frametype + frameid + bitMsb64dir + bit1_64dir + bit2_64dir + bit3_64dir + bit4_64dir + bit5_64dir + bit6_64dir + bitLsb64dir + bitMsb16dir + bitLsb16dir + broadcast_radius + options + board + ruta + data_out + dimmer + dimmer1+ tv);
putc(startbit); putc(tamamin); putc(tamamax);putc(frametype);
putc(frameid);putc(bitMsb64dir);putc(bit1_64dir);putc(bit2_64dir);
putc(bit3_64dir);putc(bit4_64dir);putc(bit5_64dir);putc(bit6_64dir);
putc(bitLsb64dir);putc(bitMsb16dir);putc(bitLsb16dir);putc(broadcast_radius);
putc(options);putc(ruta);putc(board);putc(data_out);putc(dimmer);putc(dimmer1);
putc(tv);putc(checksum);
case EDR12:
if(board = 0x09){
bit6_64dir=0xFF;  //
void main(void) {
enable_interrupts(INT_RDA);
char c;
pasar_auxRecepcionXbee();
if(auxRecepXbee[0] != 0){
for(a=0;a<=i;a++){
    putc(auxRecepXbee[a]);
limpiarAuxRecep();
a=0;
#INT_RDA
void recepcionSerie(void)
recepcionXbee[i]= getc();
       i++;
im working with Xbee modules.. the problem appears when i try to compare the variable RUTA with a switch case...
RUTA is a byte
the cases would be EDR11, EDR12, EDR13..... these are bytes too.
Any help??
PostPosted: Mon Feb 03, 2014 10:20 pm     Reply with quote
Look carefully at this function. You're missing a brace.
josue
PostPosted: Wed Feb 05, 2014 7:55 am     Reply with quote
Thank you, thank you, thank you very much PCM programmer... very helpfull...
