Watchdog timer is not working in 18F26K22
Goto page Previous  1, 2
PostPosted: Fri Jan 17, 2014 2:33 am     Reply with quote
As I said _without WDT_.
You are meant to be testing whether your chip is actually clocking at 64MHz, _first_. The code you have posted proves nothing about the clock speed, and is a waste of space.
However, add the line:
setup_oscillator(OSC_PLL_ON|OSC_16MHz);
at the start of your main.
On these chips, the PLL, when running with the internal oscillator, is a _software enabled_ option, not a fuse option. Now most modern compilers 'know' this, and will correctly enable it, but some slightly older ones need this line, and it does 'no harm' anyway.
Mike Walne
PostPosted: Fri Jan 17, 2014 4:11 am     Reply with quote
Ttelmah wrote:
Seriously, do what PCM programmer said a few posts ago, and step 'back' to a simple flash an LED program. No WDT.
Verify that at each clock rate you are trying to use, with a one second 'flash', the LED does flash at one second intervals.
Adding a watchdog, without proper code to control it, is pointless, and won't help your code reliability at all.
Please tell us what your 'blinking rates' are.
To me, you're doing too many tests.
You should not need more than two:-
1) Which does not exercise the WDT.
2) Which does with only one minor change.
Mike
PS You're also confusing me by comparing Test 3 with itself!
Test 3 : clock 4Mz, Watchdog timer prescale: 1:1(4ms)
--> LED is blinking well like test 3.but period of blinking is shorter than test 3. Namely led is blinking rapidly.
PostPosted: Fri Jan 17, 2014 6:49 am     Reply with quote
Since the 26k22 is the smaller brother of the 46k22, here's a working 'flashing LED ' program to try.
//46k22 1Hz LED test program
#include <18f46k22.h>
// #include "46k22_fuses.h"
//46k22 fuses
#fuses H4                  //uses PLL*4 speed
#fuses INTRC_IO               //use internal osc (yes !!)
//#fuses XT                  //4MHz xtal with caps
//#fuses nopllen               //disable PLL (NOT x4 speed !)
#FUSES noMCLR                    //Master Clear pin disabled,pin 1( RE3 available !)
#FUSES NOWDT                     //No Watch Dog Timer
#FUSES WDT128                    //Watch Dog Timer uses 1:128 Postscale
#FUSES NOBROWNOUT                //No brownout reset
#FUSES BORV20                    //Brownout reset at 2.0V
#FUSES PUT                       //Power Up Timer
#FUSES NOLVP                     //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#FUSES NODEBUG                   //No Debug mode for ICD
#FUSES NOPROTECT                 //Code not protected from reading
#FUSES NOCPD                     //No EE protection
#FUSES NOWRT                     //Program memory not write protected
#FUSES NOWRTD                    //Data EEPROM not write protected
#FUSES NOWRTB                    //Boot block not write protected
#FUSES NOEBTR                    //Memory not protected from table reads
#FUSES NOEBTRB                   //Boot block not protected from table reads
#FUSES NOCPB                     //No Boot Block code protection
#FUSES NOWRTC                    //configuration not registers write protected
#FUSES NOFCMEN                   //Fail-safe clock monitor enabled
#FUSES NOPBADEN                  //PORTB pins are configured as digital I/O on RESET
#FUSES STVREN                    //Stack full/underflow will cause reset
#FUSES NOIESO                    //Internal External Switch Over mode enabled
#FUSES LPT1OSC                   //Timer1 configured for low-power operation
#FUSES NOXINST                   //Extended set extension and Indexed Addressing mode disabled (Legacy mode)
#include "46k22_pins.h"
#use delay(clock=64000000)
#define LED PIN_B3
void main() {
while(1) {
output_toggle(LED);
}//***************end of forever while
}//************************end of main
please copy/paste/compile/test and confirm the LED is flashing at a 1Hz rate. I've tested this with a real 4MHz xtal/caps as well as internal osc at both 16 and 64 MHz.
hth
jay
alx
18f26k22
PostPosted: Wed Jan 29, 2014 11:46 am     Reply with quote
I have one question.
i have pic c compiler version 4.10 but i can't find the library for the 18f26k22.
anybody know where can i get it or download it?
PostPosted: Wed Jan 29, 2014 2:21 pm     Reply with quote
You'll need to upgrade your compiler !
jay
Page 2 of 2
