energetic007
how to interpret the list file |
Posted: Fri Jan 24, 2014 10:38 am |
How to interpret the list file .............
Guys i am guessing what use the list file could be put to and how it can be helpful in debugging. I know its something like the compiler produces the asm codes for the useful codes only in which some computation is done but i am curious to use it for debugging....
ROM used: 147 words (2%)
Largest free fragment is 2048
RAM used: 18 (5%) at main() level
18 (5%) worst case
Stack used: 1 locations (0 in main + 1 for interrupts)
Stack size: 8
0000: MOVLW 00
0001: MOVWF 0A
0002: GOTO 059
0003: NOP
0004: MOVWF 7F
0005: SWAPF 03,W
0006: CLRF 03
0007: MOVWF 21
0008: MOVF 0A,W
0009: MOVWF 20
000A: CLRF 0A
000B: MOVF 04,W
000C: MOVWF 22
000D: MOVF 77,W
000E: MOVWF 23
000F: MOVF 78,W
0010: MOVWF 24
0011: MOVF 79,W
0012: MOVWF 25
0013: MOVF 7A,W
0014: MOVWF 26
0015: BCF 03.7
0016: BCF 03.5
0017: MOVLW 8C
0018: MOVWF 04
0019: BTFSS 00.0
001A: GOTO 01D
001B: BTFSC 0C.0
001C: GOTO 02E
001D: MOVF 22,W
001E: MOVWF 04
001F: MOVF 23,W
0020: MOVWF 77
0021: MOVF 24,W
0022: MOVWF 78
0023: MOVF 25,W
0024: MOVWF 79
0025: MOVF 26,W
0026: MOVWF 7A
0027: MOVF 20,W
0028: MOVWF 0A
0029: SWAPF 21,W
002A: MOVWF 03
002B: SWAPF 7F,F
002C: SWAPF 7F,W
002D: RETFIE
002E: BCF 0A.3
002F: BCF 0A.4
0030: GOTO 031
.................... #INCLUDE <16F877A.H>
.................... //////// Standard Header file for the PIC16F877A device ////////////////
.................... #device PIC16F877A
.................... #list
.................... #fuses NOWDT,NOPUT,NOLVP,NOCPD
.................... #use delay(clock=4m)
.................... #byte tmr0=0x01
.................... int1 tick;
.................... int16 count=0;
.................... int16 count1=0;
.................... #INT_TIMER1
.................... void isr(void)
.................... count++;
0031: INCF 28,F
0032: BTFSC 03.2
0033: INCF 29,F
.................... if(count==5)
0034: MOVF 28,W
0035: SUBLW 05
0036: BTFSS 03.2
0037: GOTO 055
0038: MOVF 29,F
0039: BTFSS 03.2
003A: GOTO 055
.................... count=0;
003B: CLRF 29
003C: CLRF 28
.................... count1++;
003D: INCF 2A,F
003E: BTFSC 03.2
003F: INCF 2B,F
.................... output_toggle(PIN_A5);
0040: BSF 03.5
0041: BCF 05.5
0042: MOVLW 20
0043: BCF 03.5
0044: XORWF 05,F
.................... if(count1==30)
0045: MOVF 2A,W
0046: SUBLW 1E
0047: BTFSS 03.2
0048: GOTO 055
0049: MOVF 2B,F
004A: BTFSS 03.2
004B: GOTO 055
.................... count1=0;
004C: CLRF 2B
004D: CLRF 2A
.................... output_toggle(PIN_C3);
004E: BCF 2C.3
004F: MOVF 2C,W
0050: BSF 03.5
0051: MOVWF 07
0052: MOVLW 08
0053: BCF 03.5
0054: XORWF 07,F
0055: BCF 0C.0
0056: BCF 0A.3
0057: BCF 0A.4
0058: GOTO 01D
0059: MOVF 03,W
005A: ANDLW 1F
005B: MOVWF 03
005C: CLRF 29
005D: CLRF 28
005E: CLRF 2B
005F: CLRF 2A
0060: MOVLW FF
0061: MOVWF 2C
0062: BSF 03.5
0063: BSF 1F.0
0064: BSF 1F.1
0065: BSF 1F.2
0066: BCF 1F.3
0067: MOVLW 07
0068: MOVWF 1C
0069: BCF 03.7
.................... output_a(0x00);
006A: CLRF 05
006B: BCF 03.5
006C: CLRF 05
.................... output_c(0x00);
006D: MOVLW 00
006E: MOVWF 2C
006F: BSF 03.5
0070: CLRF 07
0071: BCF 03.5
0072: CLRF 07
.................... setup_adc(ADC_OFF);
0073: BCF 1F.0
.................... setup_comparator(NC_NC_NC_NC);
0074: MOVLW 07
0075: BSF 03.5
0076: MOVWF 1C
0077: MOVF 05,W
0078: MOVWF 05
0079: MOVLW 02
007A: MOVWF 77
007B: DECFSZ 77,F
007C: GOTO 07B
007D: GOTO 07E
007E: NOP
007F: MOVF 1C,W
0080: BCF 03.5
0081: BCF 0D.6
.................... setup_psp(PSP_DISABLED);
0082: BSF 03.5
0083: BCF 09.4
.................... setup_timer_0(T1_INTERNAL|T1_DIV_BY_4);
0084: MOVF 01,W
0085: ANDLW C0
0086: IORLW A5
0087: MOVWF 01
.................... enable_interrupts (GLOBAL);
0088: MOVLW C0
0089: BCF 03.5
008A: IORWF 0B,F
.................... enable_interrupts (INT_TIMER1);
008B: BSF 03.5
008C: BSF 0C.0
.................... do
.................... output_high(PIN_A3);
008D: BCF 05.3
008E: BCF 03.5
008F: BSF 05.3
.................... while(1==1);
0090: BSF 03.5
0091: GOTO 08D
0092: SLEEP
Configuration Fuses:
Word 1: 3F7B RC NOWDT NOPUT BROWNOUT NOLVP NOCPD NOWRT NODEBUG NOPROTECT |
C Turner
Posted: Fri Jan 24, 2014 11:34 am |
The things for which I find the list file to be most useful are:
- Optimizing code produced by the compiler.
- Divining the nature of compiler bugs.
On the first one, consider the following two operations on an unsigned 32 bit integer ("a") on a PIC16 processor in which one may want to align some bits with a piece of hardware or divide the value by two:
a >>= 1;
shift_right(&a, 4, 0);
They both accomplish (more or less) the same thing in that "a" gets shifted to the right one bit and divided-by-two, but if you take a look at the code listing you'll see that they produce slightly different code. In some cases - such as those where space and/or timing is at a premium - knowing what sort of C code produces the smallest, most compact assembly is crucial. (The CCS manual gives some nice examples where some "clever" C code results in very ugly, inefficient assembly.)
Another example would be for a function like "write_eeprom()" - at least in the PIC16F series. If one is writing to the EEPROM in several places throughout the code, it may go unnoticed that the entire function for doing this is repeated every time it is called, taking up quite a bit of space. Knowing that - by having looked at the list file - one could place it in its own, separate function and prevent that from happening!
When I started writing more code PIC code in C than assembly, I looked at the resulting ASM file quite often and experimented to see how the C code affected the efficiency of the resulting code - the result of this is that my PIC C code often looks a bit different from code that I would write on a system from which I was more separated from the hardware.
Another good reason to at least take a look at the list file now and then is that is refreshes the understanding of the PIC's opcodes and hardware structure: Maintaining touch with this aspect of the hardware is very important when writing code for an embedded processor as you really cannot (and should not!) stray too far if you want to write reasonably efficient code on a processor with (usually!) very limited resources.
The other point - divining compiler bugs. Most of the time, they are really *my* bugs, but on occasion, once the problem has been distilled to its essence (that is, you have written code with the fewest-possible number of lines that clearly demonstrates the issue) being able to step through code of minimal complexity better allows an understanding of the problem.
The most recent example for me was when, in some early versions of the 5.x compiler, simply using "sprintf" caused the interrupts to be turned off. The problem, isolated in a simple example, was passed to the CCS folks and fixed in the very next release.
Another thing that is not always appreciated is demonstrated in your example: Even code that might seem to do nothing on the first examination (e.g. compiler directives) can cause surprising amount of code to be generated - say, to zero at the RAM, set up hardware, etc. and if space is at a premium, a close examination of the list file might well reveal unnecessary "goings on" that, in a specific case, could be safely omitted.
I'm sure that there are many more instances/examples, but the above two are those that come to mind first.
CT |
Posted: Fri Jan 24, 2014 12:00 pm |
The first thing to look at is your fuses. Instantaneous recognition of a bug:
The compiler defaults to the RC fuse when you don't specify an oscillator
fuse. The RC fuse is a primitive hobbyist-type oscillator, left over from
the early days of the PIC, consisting of an external Resistor-capacitor
circuit. |
