rrb011270
Anybody have done this code... |
Posted: Tue Oct 07, 2003 11:32 pm |
Mabuhay!
Anyone in the forum have done I2C using hardware for writing/reading to FM24C256 w/o using the ccs built-in functions....
It wud be better if somebody share to me a sample code which use interrupt and hardware I2C at the same time...
Any help will do?
Thnx |
Mark
Posted: Wed Oct 08, 2003 6:29 am |
See below
Mark
Posted: Wed Oct 08, 2003 6:30 am |
This code does not use interrupts but does use the hardware i2c. It does not use any CCS functions since I wrote it for the Microchip C18 compiler. I didn't post all the typedefs but they should be clear. Also note that this was done for a 24C08 so the addressing scheme would be a little different but it should give you a starting point.
Useful defines for writing to the I2C bus
#define I2C_IDLE() while ((SSPCON2 & 0x1F) || (SSPSTATbits.R_W))
#define I2C_START() \
SSPCON2bits.SEN = 1; \
while (SSPCON2bits.SEN) \
_asm nop _endasm \
#define I2C_RESTART() \
SSPCON2bits.RSEN = 1; \
while (SSPCON2bits.RSEN) \
_asm nop _endasm \
#define I2C_STOP() \
SSPCON2bits.PEN = 1; \
while (SSPCON2bits.PEN) \
_asm nop _endasm \
#define I2C_WRITE(x) \
SSPBUF = (x); \
while (SSPSTATbits.BF) \
_asm nop _endasm \
I2C_IDLE()
#define I2C_READ(x) \
SSPCON2bits.RCEN = 1; \
while (SSPCON2bits.RCEN) \
_asm nop _endasm \
SSPCON2bits.ACKDT = (x); \
SSPCON2bits.ACKEN = 1; \
while (SSPCON2bits.ACKEN) \
_asm nop _endasm \
static BOOLEAN I2C_Device_Ready(UINT8 id);
void EEPROM_Write_Internal(UINT8 data, UINT16 address);
UINT8 EEPROM_Read_Internal(UINT16 address);
void EEPROM_Write_Byte(UINT8 data, UINT16 address);
UINT8 EEPROM_Read_Byte(UINT16 address);
void EEPROM_Write_String(char *s, UINT16 address);
void EEPROM_Read_String(char *s, UINT16 address);
void EEPROM_Write_Block(char *data, UINT8 len, UINT16 address);
void EEPROM_Read_Block(char *data, UINT8 len, UINT16 address);
DESCRIPTION: This function checks to see if an i2c device will ACK
RETURN: TRUE if device ACKed otherwise FALSE
ALGORITHM: none
NOTES: none
UINT8 id) /* FIX ME: add comment */
do
/* Important to clear these bits before we attempt to write */
PIR2bits.BCLIF = 0;
SSPCON1bits.WCOL = 0;
I2C_IDLE(); /* ensure module is idle */
I2C_START();
} while (PIR2bits.BCLIF);
I2C_WRITE(id);
if (!SSPCON2bits.ACKSTAT) /* test for ACK condition, if received */
return (TRUE);
return (FALSE);
DESCRIPTION: This function writes the passed data to the specified
address of the serial eeprom.
RETURN: none
ALGORITHM: none
NOTES: none
UINT8 data, /* byte written to seeprom */
UINT16 address) /* SEEPROM address to write data */
UINT8 control;
/* MSB if address > 0xFF. Should be in bit1 */
control = SEEPROM_WRITE_MODE | ((UINT8) (address >> 8) << 1);
while (!I2C_Device_Ready(control));
I2C_WRITE((UINT8) address);
I2C_WRITE(data);
I2C_STOP();
DESCRIPTION: This function reads a byte of data in from the serial
eeprom at the specified address.
RETURN: data byte read from SEEPROM
ALGORITHM: none
NOTES: none
UINT16 address) /* seeprom address to write data */
UINT8 control;
control = SEEPROM_WRITE_MODE | (UINT8) (address >> 8) << 1;
I2C_RESTART();
I2C_WRITE(control + 1);
I2C_READ(1);
I2C_STOP();
return (SSPBUF); /* return with data */
DESCRIPTION: This function writes a byte of data to the specified
address of the internal eeprom.
RETURN: none
ALGORITHM: none
NOTES: none
UINT8 data, /* byte written to eeprom */
UINT16 address) /* EEPROM address to write data */
EEADRH = address >> 8; /* Load our address */
EEADR = address; /* Load our address */
EEDATA = data; /* Load our data */
EECON1bits.EEPGD = 0; /* Point to data memory */
EECON1bits.WREN = 1; /* Enable writes */
/* Microchip recommends disabling ints here */
Global_Int(INT_DISABLED);
EECON2 = 0x55; /* Write 0x55 */
EECON2 = 0xAA; /* Write 0xAA */
EECON1bits.WR = 1; /* Set WR to begin write */
_asm nop _endasm
Global_Int(INT_RESTORE);
while (EECON1bits.WR) /* Wait for write to complete */
_asm nop _endasm
EECON1bits.WREN = 0; /* Disable writes */
return;
DESCRIPTION: This function reads a byte of data in from the internal
RETURN: data - byte read from SEEPROM
ALGORITHM: none
NOTES: none
UINT16 address) /* eeprom address to write data */
EECON1bits.RD = 1; /* EEPROM Read */
return (EEDATA); /* Return with our value */
DESCRIPTION: This function writes a string to the SEEPROM
RETURN: none
ALGORITHM: none
NOTES: The routine should handle going across chip boundaries
char *s, /* string to write to seeprom */
EEPROM_Write_Block(s, strlen(s) + 1, address);
DESCRIPTION: This function reads a string from the serial eeprom at the
specified address.
RETURN: none
ALGORITHM: none
NOTES: This routine does not cross chip boundaries
char *s, /* point to the string to load */
UINT8 control;
/* check for a valid pointer */
if (s == 0)
return;
I2C_RESTART();
while (TRUE)
I2C_READ(0);
*s = SSPBUF;
if (*s == 0)
s++;
/* Terminate the read sequence */
I2C_READ(1);
I2C_STOP();
DESCRIPTION: This function writes a block of data to the SEEPROM
RETURN: none
ALGORITHM: none
char *data, /* pointer to the block of data to write */
UINT8 len, /* number of bytes to write */
UINT8 control;
UINT8 lastpage;
UINT8 page;
/* determine the control word for the device */
/* Wait until our device is ready */
/* Set the address pointer in the device */
page = (UINT8) address >> 4;
lastpage = page;
while (len)
if (page != lastpage)
/* Issuing a STOP will start the write sequence */
I2C_STOP();
lastpage = page;
I2C_WRITE(*data);
data++;
address++;
/* The 24C08 has a 16 byte page for writing. */
len--;
I2C_STOP();
DESCRIPTION: This function reads a block of data from the serial eeprom
RETURN: none
ALGORITHM: none
char *data, /* point to the data to load */
UINT8 len, /* number of bytes to read */
UINT8 control;
I2C_RESTART();
while (len > 1)
I2C_READ(0);
*data = SSPBUF;
data++;
len--;
I2C_READ(1);
*data = SSPBUF;
I2C_STOP();
rrb011270
Posted: Wed Oct 08, 2003 5:29 pm |
what is the purpose of "\" symbol?
Quote: | #define I2C_IDLE() while ((SSPCON2 & 0x1F) || (SSPSTATbits.R_W))
_asm nop _endasm \
rrb011270
Posted: Wed Oct 08, 2003 7:39 pm |
Hi Mark,
With the code u mention... Do I have to have to use the #use i2c(master,...)?
thnx |
Mark
Posted: Wed Oct 08, 2003 7:52 pm |
The "\" means continuation. It is a way to break up a long line of C code.
You will have to set up the ssp. I don't use the #use i2c. As I said before, this was done for the C18 compiler which does not have the CCS functions. |
Posted: Wed Oct 08, 2003 9:43 pm |
Hi Mark,
I compile the code u shared but it report an error with an unknown indentifier "_asm".
Can u check if this will work in PIC18452.
Thnx |
Mark
Posted: Thu Oct 09, 2003 6:10 am |
This code was written for the MICROCHIP C18 compiler! Although it is C, you will have to make a few changes. CCS embeds their assembly a little differently. The Global_Int() function is one that I wrote that saves the current state of the interrupts (high and low priority) when they are disabled. I can then call the restore and they are set back to the state before I disabled them. This keeps me from enabling interrupts if they were already disabled for some reason. Also note that you will have to define all the registers. |
Posted: Thu Oct 09, 2003 5:19 pm |
Would it be possible to share a simple code snippet regarding Global_Int() and restore function? maybe I can utilize it with my application.
Thnx
Mark wrote: | This code was written for the MICROCHIP C18 compiler! Although it is C, you will have to make a few changes. CCS embeds their assembly a little differently. The Global_Int() function is one that I wrote that saves the current state of the interrupts (high and low priority) when they are disabled. I can then call the restore and they are set back to the state before I disabled them. This keeps me from enabling interrupts if they were already disabled for some reason. Also note that you will have to define all the registers. |
rrb011270
Posted: Sat Oct 11, 2003 6:22 am |
Quote: | This code does not use interrupts but does use the hardware i2c. It does not use any CCS functions since I wrote it for the Microchip C18 compiler. I didn't post all the typedefs but they should be clear. Also note that this was done for a 24C08 so the addressing scheme would be a little different but it should give you a starting point. |
I have successfully converted the code u shared to PIC18452... I'll post this coming monday for others can have it use it in der project...
Tengkyu |
rrb011270
Posted: Tue Oct 14, 2003 8:26 am |
I have succesfully coded the source below for the PIC18F452...
I write to an external FRAM without affecting my timer interrupt (RTC) and other interrupt that I use (e.g. rda, tbe, timer1)... and it really did write without hanging-up my system..
My only convern is that would this affect my RTC and other interrupts if I am to read block of data from FRAM memory? say read 128bytes of data and send it to serial using interrupt(#int_rda)? such that my host PC will parse it.....
Anybody who can give me a tips, comments or any help will do....
Mark wrote: | This code does not use interrupts but does use the hardware i2c. It does not use any CCS functions since I wrote it for the Microchip C18 compiler. I didn't post all the typedefs but they should be clear. Also note that this was done for a 24C08 so the addressing scheme would be a little different but it should give you a starting point.
_asm nop _endasm \
_asm nop _endasm \
_asm nop _endasm \
SSPBUF = (x); \
_asm nop _endasm \
I2C_IDLE()
_asm nop _endasm \
_asm nop _endasm \
ALGORITHM: none
NOTES: none
do
PIR2bits.BCLIF = 0;
I2C_START();
I2C_WRITE(id);
return (TRUE);
return (FALSE);
RETURN: none
ALGORITHM: none
NOTES: none
UINT8 control;
I2C_WRITE(data);
I2C_STOP();
ALGORITHM: none
NOTES: none
UINT8 control;
I2C_RESTART();
I2C_READ(1);
I2C_STOP();
RETURN: none
ALGORITHM: none
NOTES: none
_asm nop _endasm
_asm nop _endasm
return;
ALGORITHM: none
NOTES: none
RETURN: none
ALGORITHM: none
specified address.
RETURN: none
ALGORITHM: none
UINT8 control;
if (s == 0)
return;
I2C_RESTART();
while (TRUE)
I2C_READ(0);
*s = SSPBUF;
if (*s == 0)
s++;
I2C_READ(1);
I2C_STOP();
RETURN: none
ALGORITHM: none
UINT8 control;
UINT8 lastpage;
UINT8 page;
lastpage = page;
while (len)
I2C_STOP();
lastpage = page;
I2C_WRITE(*data);
data++;
address++;
len--;
I2C_STOP();
RETURN: none
ALGORITHM: none
UINT8 control;
I2C_RESTART();
while (len > 1)
I2C_READ(0);
*data = SSPBUF;
data++;
len--;
I2C_READ(1);
*data = SSPBUF;
I2C_STOP();
