Read voltage using 16f877 with 12bit External Adc (ltc1297)
CSharpdeveloper
PostPosted: Sun Jan 12, 2014 3:57 pm     Reply with quote
i tried the following codes for using 12bit external adc.
i have a problem about 12bit external adc. i am using ltc1297 12bit adc and pic16f877. The obtained voltage value is not true. The proteus scheme and CCS C codes are as follows.
the proteus file and ccs codes are present in the following links.
Link: http://www.dosyasitesi.com/download.php?file=819e28c743d6d74c632d4802f44d87e6
For example:
While the pot value is 0V, the obtained voltage value is 0.009V.
While the pot value is 1V, the obtained voltage value is 3.003V.
While the pot value is 2.5V, the obtained voltage value is 0.000V.
While the pot value is 4V, the obtained voltage value is 1.996V.
While the pot value is 5V, the obtained voltage value is 5.000V.
#include <16f877.h>
#include <ltc1297.c>
void display_data( long int data ) {
     char volt_string[6];
     convert_to_volts( data, volt_string );
     printf(volt_string);
     printf(" (%4lX)",data);
 long int value;
   adc_init();
   printf("Sampling:\r\n");
   do {
      value = read_analog(0);
      printf("\n\rCh0: ");
      display_data( value );
   } while (TRUE);
#ifndef ADC_CS
#define ADC_CLK  PIN_B0
#define ADC_DOUT PIN_B1
#define ADC_DIN  PIN_B2
#define ADC_CS   PIN_B3
void adc_init() {
   output_high(ADC_CS);
void write_adc_byte(BYTE data_byte, BYTE number_of_bits) {
   BYTE i;
   delay_us(2);
   for(i=0; i<number_of_bits; ++i) {
      if((data_byte & 1)==0)
        output_low(ADC_DIN);
        output_high(ADC_DIN);
      data_byte=data_byte>>1;
      output_high(ADC_CLK);
      delay_us(50);
      output_low(ADC_CLK);
      delay_us(50);
BYTE read_adc_byte(BYTE number_of_bits) {
   BYTE i,data;
   data=0;
   for(i=0;i<number_of_bits;++i) {
      delay_us(50);
      shift_left(&data,1,input(ADC_DOUT));
      delay_us(50);
   return(data);
long int read_analog( BYTE channel ) {
   int l;
   long int h;
   delay_us(200);
   output_low(ADC_CS);
   if(channel==0)
     channel=0x1b;
   write_adc_byte( channel, 5);
   h=read_adc_byte(8);
   l=read_adc_byte(4)<<4;
   return((h<<8)|l);
void convert_to_volts( long int data, char volts[6]) {
   BYTE i;
   long int temp,div;
   div=0x3330;
   for(i=0;i<=4;i++) {
     temp=data/div;
     volts[i]=(BYTE)temp+'0';
     if(i==0) {
       volts[1]='.';
       i++;
     temp=div*(BYTE)temp;
     data=data-temp;
     div=div/10;
   volts[i]='\0';
proteus scheme:
link1: http://s16.postimg.org/71akbx8xh/image1.png
link2:
jpg upload
asmboy
PostPosted: Sun Jan 12, 2014 7:52 pm     Reply with quote
BUILD the project with real hardware.
you don't even have a safe circuit design for the LTC converter.
check its data sheet.
then see if it works.
NOBODY here trusts or will respond to proteus questions.
PostPosted: Sun Jan 12, 2014 9:11 pm     Reply with quote
Please read PIC101 and you'll see why real PICsters use real PICs in the real world. Your Proteus schematic has over 11 errors and can not work in the real world. There's probably a coding issue as well but that could easily be an internal Proteus problem as it's full of 'bugs'.
I strongly urge you to wire up the 877 and run the CCS example code for the internal ADC peripheral. First in 8 bit mode, then 10 bit. Once you've gotten it to work 100% then wire up the external ADC.
Getting a 12 bit ADC to work reliably requires the use of an accurate and stable Vref, great ground planes and careful board layout. The best I've achieved is +-3 bits using those same components.
Also the '877 is, well, obsolete and you should use a newer PIC. There are several pin-for-pin compatible ones now, not only cheaper but with more features.
hth
jay
dorinm
PostPosted: Tue Jan 14, 2014 3:49 am     Reply with quote
#ifndef ADC_CS
void adc_init() {
unsigned int16 read_ltc1297(void) {
   unsigned int8 i;
   unsigned int16 data;
   data=0;
   output_low(ADC_CS);
   delay_us(50);
   //first clock
   delay_us(50);
   delay_us(50);
   //null_bit
   delay_us(50);
   delay_us(50);
   for(i=0;i<11;++i) {
      delay_us(50);
      delay_us(50);
   // now read the data
   for(i=0;i<12;++i) {
      delay_us(50);
      shift_right(&data,2,input(ADC_DOUT));
      delay_us(50);
   delay_us(50);
   delay_us(50);
   data>>=4;
   data&=0X0FFF;
   return(data);
...and volts=data*vref/0x0FFF
CSharpdeveloper
Thanks to dorinm
PostPosted: Wed Jan 15, 2014 6:19 pm     Reply with quote
Thank you very much for all advice (Especially to dorinm). I tried the code and see that the code is working correctly. My problem is solved by dorinm.
Best regards.
