question in interrupts
maxD
PostPosted: Sun Dec 29, 2013 5:22 am     Reply with quote
following code is for led blinking
when i press push button led on and blinks till i press it again(then it will off)
#include<18f2550.h>
#fuses NOWDT,HS,NOPROTECT,NOLVP
//#use rs232(baud=9600,UART1,ERRORS, parity=N,bits=8)
BYTE blink=0;
#INT_EXT
void led()
  if(!input(PIN_B0)&&!blink)
    blink=1;
  else if(!input(PIN_B0)&&blink)
    blink=0;
   int i=0;
   enable_interrupts(INT_EXT_H2L);
   do{
     if(blink)
       output_high(PIN_B1);
       output_low(PIN_B1);
   }while(TRUE);
problem is i want to know after isr finished working what will be the next line the pic begin to execute
is it start from do
or from void main()?
thanks!!!!
PostPosted: Sun Dec 29, 2013 6:21 am     Reply with quote
probably neither
The PIC will execute the next instruction that follows the one WHEN the interrupt occurred.
Let's say your program has 12 lines of code and the interrupt occurred during the 7th line.The PIC fishes that line,then does the ISR, then returns to the 8th line and carries on.
This is the usual way it's done. A programmer can alter this if course if he so desires but NOT recommended for the novice programmer.
hth
jay
maxD
PostPosted: Sun Dec 29, 2013 7:08 am     Reply with quote
thanks
bkamen
PostPosted: Sun Dec 29, 2013 11:52 pm     Reply with quote
temtronic wrote:
probably neither
wait wait...
A "line" of C code may compile to multiple instructions.
Let the OP understand that a line that simple states X += 2 can be interrupted somewhere in that line because it consists of multiple instructions.
Cheers,
-Ben
PostPosted: Mon Dec 30, 2013 1:23 am     Reply with quote
Yes. An important distinction, especially if things like printf are involved. This is whey you get so many posts about values being corrupted, where a value is updated in an interrupt....
