gets() problem
Mahdi
gets() problem
PostPosted: Sun Dec 29, 2013 5:24 am     Reply with quote
hi buddies
i want to send string and receive with uart protocol in isis simulator
transmitter code :
#include <33FJ32MC204.h>
#use delay(crystal=80M)
#pin_select U1TX=PIN_C6
#pin_select U1RX=PIN_C7
#use rs232(UART1, baud=230400,errors)
#include <stdio.h>
#include <string.h>
#INCLUDE <stdlib.h>
#include <LCD.C>
signed int8 x=10,y=-20,z=35,a=0;
unsigned int8 trt,batt;
char trt1[40],x1[10],y1[10],z1 [10],crt[2];
strcpy(trt1,"");
strcpy(x1,"");
strcpy(y1,"");
strcpy(crt,",");
itoa(trt,10, trt1);
itoa(x,10, x1);
itoa(y,10, y1);
itoa(z,10, z1);
strcat(trt1,crt);
strcat(trt1,x1);
strcat(trt1,crt);
strcat(trt1,y1);
strcat(trt1,crt);
strcat(trt1,z1);
lcd_gotoxy(1,1);
printf(lcd_putc,"%s",trt1);
puts(trt1);
delay_ms(10);
receiver code :
#include <33fj32mc204.h>
#use delay(crystal=80m)
#use i2c(MASTER,I2C1,FAST)
#use rs232(UART1,baud=230400,errors)
#define gyro_xsens 6
#define gyro_ysens 6
#define gyro_zsens 6
#include <var.c>
#INCLUDE <lcd.c>
char x1 [40],bb;
#INT_RDA
void  rda_isr(void)
output_high(pin_a1);
gets(x1);
bb=getc();
output_low(pin_a1);
#INT_TIMER3
void  timer3_isr(void)
output_high(pin_a0);
i2c_start();
i2c_write(0xd0);
i2c_write(0x43);
i2c_start();
i2c_write(0xd1);
gxh=i2c_read(1);
gxl=i2c_read(0);
i2c_stop();
 i2c_start();
i2c_write(0xd0);
i2c_write(0x45);
i2c_start();
i2c_write(0xd1);
gyh=i2c_read(1);
gyl=i2c_read(0);
i2c_stop();
 i2c_start();
i2c_write(0xd0);
i2c_write(0x47);
i2c_start();
i2c_write(0xd1);
gzh=i2c_read(1);
gzl=i2c_read(0);
i2c_stop();
   gx = make16(gxh,gxl) - gx_OFFSET;
   gy = make16(gyh,gyl) - gy_OFFSET;
   gz = make16(gzh,gzl) - gz_OFFSET;
   gxrate = gx/gyro_xsens;
   gyrate = gy/gyro_ysens;
   gzrate = gz/gyro_zsens;
output_low(pin_a0);
void main(){
setup_timer3(TMR_INTERNAL | TMR_DIV_BY_64, 1562);
enable_interrupts(INT_timer3);
enable_interrupts(INT_RDA);
   while(TRUE){
i use pin a1 for rda interrupt to measure period of interrupt(blue line)
and pina0 for timer3 interrupt to measure............. (yellow line)
in rda interrupt i have 500 us delay until data received
in timer3 interrupt i have 90 us delay until interrupt finished and timer3 set to 2.5 ms and fire.
all things is work but After a period of time, rda interrupt lock for 10 ms why?
ccs v 5
thanks
Gabriel
PostPosted: Sun Dec 29, 2013 6:13 am     Reply with quote
Thats one strange baud rate.
Read the sticky post related to Proteus.
Why not just make a small sample program to comunicate between the pics first and then include all the other stuff you are doing? That way you know your comms are working.
G.
CCS PCM 5.078 & CCS PCH 5.093
PostPosted: Sun Dec 29, 2013 8:19 am     Reply with quote
A number of comments ignoring Proteus....
1) What is the maximum crystal frequency the chip supports?......
This will stop the code working in a real chip.
2) INT_RDA, implies _one_ character is available to be read. Do a search here for why you should not use 'gets' in this interrupt, and for replacements.
INT_RDA used like this will lock the receive chip, till a line feed is seen.
Mahdi
PostPosted: Sun Dec 29, 2013 12:30 pm     Reply with quote
thanks
when i disable timer3 interrupt the rda interrupt work without any problem.
In my opinion the getc() clear buffer and flag of interrupt but gets() cant it.
now i should clear flag of uart receiver but how ?
andrewg
PostPosted: Mon Dec 30, 2013 12:59 am     Reply with quote
gets will clear the buffer and interrupt flag, but it's the wrong function for a serial interrupt handler. You might think it's working, but it isn't. INT_RDA is called for each character and you need to call getc() exactly once for each interrupt. Usually your interrupt handler will put each character into a buffer which your mainline loop will read. See the CCS example "EX_SISR.C". If you need gets() functionality, you will need to write it yourself.
Andrew
