lcd display *** Duplicate post
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion
madhunica
PostPosted: Thu Dec 26, 2013 11:28 pm     Reply with quote
Locked.
Reason: Duplicate thread on same lcd topic.
Add new questions to your original thread:
http://www.ccsinfo.com/forum/viewtopic.php?t=51639
Do not use PicBasic Pro lcd driver. Use CCS lcd driver.
- Forum Moderator
#include <16F877.h>                           // Preprocessor directive that selects the chip
#fuses HS,NOWDT,NOPROTECT,NOLVP                // Preprocessor directive that defines the chip fuses
#use delay(clock=20000000)                     // Preprocessor directive that specifies clock speed
#use rs232(baud=9600, xmit=PIN_C6, rcv=PIN_C7) // Preprocessor directive that includes RS232 libraries
#include "lcd.c"
#define ADC_CLOCK 3
#define LCD_RSBIT 1
#define LCD_EREG pin_b6
#define LCD_EBIT 1
#define LCD_COMMANDUS 2000
#define LCD_DATAUS 50
#define LCD_INITMS 1
#define LCD_INIT1
LCD_INIT();
int8 TRIS_valueB=0x00;
int8 tris_valuec=0x00;
set_tris_b(tris_valueb);
set_tris_c(tris_valuec);
output_bit(pin_b7,0x01);
output_bit(pin_b6,0x01);
while(true)
byte x,y,z;
printf("HiThere");
printf("%2u %X %4X\n\r",x,y,z);
printf(LCD_PUTC, "n=%u",1);
DELAY_ms(1);
when i compile this program i found no error but i didn't get the simulator output......can you help me ....
gpsmikey
PostPosted: Thu Dec 26, 2013 11:49 pm     Reply with quote
don't know about the simulator (it has it's own series of bugs), but one problem you have is there needs to be a delay after reset goes away before you call LCD_INIT - the LCD controllers typically require additional time to power up before you can talk to them. Check out the spec sheets for the common controllers (or whatever one you are using).
mikey
mikey
Post new topic   This topic is locked: you cannot edit posts or make replies.    CCS Forum Index -> General CCS C Discussion All times are GMT - 6 Hours
