my compiler (PCH 5.016) say:
"Unknown PIC Device, USB not supported in this library."
Can you update the library?
Thank you & best regards _________________ -----------------
Fabrizio Binotti
Posted: Sun Dec 22, 2013 12:00 pm
You need to ask CCS.
This is a _user_ forum, not 'technical support'. Note what it says at the top of the page. Quote:
"CCS does not monitor this forum on a regular basis".
Posted: Sun Dec 22, 2013 3:42 pm
However, that having been said, if you
'#DEFINE USB_HW_GENERIC_18F67J50'
the existing library should work. Obviously you'll need to set the fuses and clocks to match your chip, but the actual USB hardware is standard for the more complex chips with buffering selectable to anywhere in memory.
