datatype problem
hemnath
datatype problem
PostPosted: Fri Dec 06, 2013 10:25 pm     Reply with quote
I'm using PIC18F2520, CCS C Compiler, Version: 4.114, Oscillator: 2Mhz
Reading eeprom values, but the values are wrong. Why is it so?
reading a 16 bit number and saving it in float. It creates problem. Why is it?
sample program:
#include "18F2520.h"
#fuses INTRC_IO
#use delay(clock = 2000000)
#define LOW_CAL_ADC_ADDRESS      20
#define LOW_CAL_DISP_ADDRESS   30
#define HIGH_CAL_ADC_ADDRESS   40
#define HIGH_CAL_DISP_ADDRESS   50
float adc_span;
float disp_span;
float leastcount;
#define INT_EEPROM_ADDRESS  int8
void write_int16_eeprom(INT_EEPROM_ADDRESS address, int16 data);
int16 read_int16_eeprom(INT_EEPROM_ADDRESS address);
// Purpose:    Write a 16 bit number to internal eeprom
// Inputs:     1) An eeprom address
//             2) The 16 bit number to write to internal eeprom
// Outputs:    None
   int8 i;
   for(i = 0; i < 2; ++i)
     write_eeprom(address + i, *((int8 *)(&data) + i));
// Purpose:    Read a 16 bit number from internal eeprom
// Inputs:     An eeprom address
// Outputs:    The 16 bit number read from internal eeprom
   int8  i;
   int16 data;
     *((int8 *)(&data) + i) = read_eeprom(address + i);
   return(data);
   write_int16_eeprom(LOW_CAL_ADC_ADDRESS, 3000);
   write_int16_eeprom(HIGH_CAL_ADC_ADDRESS, 23000);
   write_int16_eeprom(LOW_CAL_DISP_ADDRESS, 9000);
   write_int16_eeprom(HIGH_CAL_DISP_ADDRESS, 0);
   adc_span = read_int16_eeprom(HIGH_CAL_ADC_ADDRESS) - read_int16_eeprom(LOW_CAL_ADC_ADDRESS);
   disp_span = read_int16_eeprom(HIGH_CAL_DISP_ADDRESS) -   read_int16_eeprom(LOW_CAL_DISP_ADDRESS);
   leastcount = disp_span/adc_span;
Read the values in watch window using mplab,
values are,
adc_span = 20000.0000
disp_span = 56536.0000 // wrong value...
leastcount = 2.82680011
PostPosted: Sat Dec 07, 2013 12:11 am     Reply with quote
Learn to trouble-shoot the problem. Use printf to display intermediate
results in the math formula.
That's an assumption. Load the result into an int16 value and display
that result with printf. What do you get ?
hemnath
PostPosted: Sat Dec 07, 2013 12:21 am     Reply with quote
changed the code to
disp_span = (float)read_int16_eeprom(HIGH_CAL_DISP_ADDRESS) -   (float)read_int16_eeprom(LOW_CAL_DISP_ADDRESS);
value on mplab, disp_span = -9000.
Looks good.
PostPosted: Sat Dec 07, 2013 2:03 am     Reply with quote
It is worth understanding what was wrong.
An 'int' or 'int16', is an _unsigned_ value in CCS.
0-9000 is a _negative_ result. Impossible in an unsigned.
Since integer arithmetic 'wraps', 0-9000 will give 65536-9000 = 56536.
