pic18F4550 I2C with HYT-271
Prefekt
PostPosted: Tue Dec 03, 2013 1:35 pm     Reply with quote
I try to get values from a HYT-271 sensor. The sensor is connected with I2C.
But the sensor will not send data! Crying or Very sad
Has anybody experience with this or similar sensors?
The protocol description is here:
http://www.ist-ag.com/eh/ist-ag/resource.nsf/imgref/Download_AHHYT-I2C_E1.2.pdf/$FILE/AHHYT-I2C_E1.2.pdf
thanks
ezflyr
PostPosted: Tue Dec 03, 2013 2:47 pm     Reply with quote
Yes, in line 37 of your code replace the '=' with a '==', and that should solve the problem. Also, add 'Errors' to your #use rs232 declaration. Wink
John
PS how are we supposed to offer any constructive suggestions if you don't post your code?
Prefekt
PostPosted: Wed Dec 04, 2013 1:18 pm     Reply with quote
Very Happy
Ok, in the protocol datasheet are two different commands, DF 'Data Fetch' and MR 'Measuring Request'
The sensor address is 0x28:
first step: send MR with address and last bit = 0 as write
next: send DF with address and last bit =1 as read
next: read Data
next: read Data
next: read Data
next: read Data
I have no experience with i2c... here' a code snippet:
      i2c_start();
      status = i2c_write(0b01010000);
      if(status != 0)
         printf("MR: no sensor found\n\r");
         continue;
      printf("MR: ok\n\r");
      i2c_stop();
      delay_ms(50);
      i2c_start();
      status = i2c_write(0b01010001);
      if(status != 0)
         printf("DF: no sensor found\n\r");
         continue;
      printf("DF: ok\n\r");
      i[0] = i2c_read();
      i[1] = i2c_read();
      i[2] = i2c_read();
      i[3] = i2c_read();
      i2c_stop();
      printf("%x # %x # %x # %x \n\r", i[0], i[1], i[2], i[3]);
the output is:
MR: ok
DF: ok
ff # ff # ff # ff
MR: ok
DF: ok
ff # ff # ff # ff
MR: ok
DF: ok
ff # ff # ff # ff
MR: ok
DF: ok
ff # ff # ff # ff
Prefekt
PostPosted: Tue Dec 17, 2013 11:49 pm     Reply with quote
Now, the sensor is working - sometimes.
The read values are wrong. At the first read / write the sensors answers, but the than ' status = i2c_write(AddressWrite);' failed.
void GetSensorData(char AddressWrite, char AddressRead)
   int status=0;
   int i=4;
   i2c_start();
   if(status != 0)
      printf("MR: no sensor found at:%x \n\r", AddressWrite);
      continue;
   i2c_stop();
   i2c_start();
   status = i2c_write(AddressRead);
   if(status != 0)
      printf("DF: no sensor found at: %x \n\r", AddressRead);
      continue;
   for (i=0;i<4;i++)
      messageBuf[i] = i2c_read();
   i2c_stop();
   printf("%x # %x # %x # %x \n\r", messageBuf[0], messageBuf[1], messageBuf[2], messageBuf[3]);
