pilar
| Warning !! (SOLVED) |
Posted: Thu Nov 28, 2013 11:20 am |
Hi, someone can tell me how I can remove this Warning, it is affecting my program.
| Code: | Executing: "D:\Archivos de programa\Microchip\PICC\Ccsc.exe" +FH "RTC1.C" +DF +LN +T +A +M +Z +Y=9 +EA
>>> Warning 203 "D:\Proyectos\Poste_SOS\CCS-PIC\DS1307.h" Line 123(1,1): Condition always TRUE
>>> Warning 216 "RTC1.C" Line 616(0,1): Interrupts disabled during call to prevent re-entrancy: (Ini_buff_rec)
>>> Warning 216 "RTC1.C" Line 616(0,1): Interrupts disabled during call to prevent re-entrancy: (@delay_ms1)
>>> Warning 216 "RTC1.C" Line 616(0,1): Interrupts disabled during call to prevent re-entrancy: (inicbuff)
>>> Warning 202 "RTC1.C" Line 11(5,8): Variable never used: rs232_errors
Memory usage: ROM=30% RAM=13% - 14%
It may be that someone might have the same problem...
http://www.ccsinfo.com/faq.php?page=interrupts_disabled
Joined: 01 Jul 2010 Posts: 9606 Location: Greensville,Ontario
Posted: Thu Nov 28, 2013 12:20 pm |
Actually 'warnings' do not affect programs.
The first 3 tell you that interrupts are disabled within an ISR, This is normal and will not affect your program
The 4th says that a variable is never used,again normal.
Warnings will NOT stop the compiler from creating executable code,meary inform you of a 'condition'.
Now if your program doesn't work, then post it(or a small,compilable one) that shows us what's going on..or...better explain why you want the 'warnings' to not appear.
hth
jay |
