any example to use PWM control for PIC16F877A
artohautala
PostPosted: Sun Nov 24, 2013 10:02 am     Reply with quote
I want to use PIC16F877A pin C2 to control the brightness of the backround light of LCD display... with pulse width modulation.
I have FET connected to pin C2 and on/off control works fine.
Is there any example how to use PWM module for that purpose ?
I understand how pulse width modulation works in theory but I had no success to get it work though I tried it make to work in many ways ...
if you want please help me ...
I do not understand this ccs manual good example how to use it:
// For a 20 mhz clock, 1.2 khz frequency,
// t2DIV set to 16
// the following sets the duty to 50% (or 416 us).
long duty;
duty = 512; // .000416/(16*(1/20000000))
set_pwm1_duty(duty);
I'm very pleased for this good discussion forum ...
all the best for you all
-arto-
asmboy
PostPosted: Sun Nov 24, 2013 12:53 pm     Reply with quote
you need to:
** setup timer 2 for frequency control
and then
** setup the pwm module for PWM output
per the ccs manual
CCS compiler will handle the TRIS for you
look at MR.T's code in this post
http://www.ccsinfo.com/forum/viewtopic.php?t=51167&highlight=pwm+setup
artohautala
PostPosted: Sun Nov 24, 2013 1:03 pm     Reply with quote
asmboy wrote:
you need to:
and then
per the ccs manual
OK
very good ... but how I do it in practice ?
asmboy
PostPosted: Sun Nov 24, 2013 1:33 pm     Reply with quote
see figure 2 for a block diagram of a useful circuit
http://www.electronicsnews.com.au/features/power-converters-stretch-battery-budget
artohautala
PostPosted: Sun Nov 24, 2013 1:49 pm     Reply with quote
maybe wrong link Wink
asmboy
PostPosted: Mon Nov 25, 2013 7:47 am     Reply with quote
fig 2 is a simple block diagram of a buck modulator
which is a classic way to use PWM for adjusting the output power of a fixed supply. with a 5V dc input - substitute a P channel FET for the transistor, and direct drive the gate with the PIC PWM Output to vary the power sent to an LED back light and your problem is solved.
