Disable RX pin
pulurumbuluruciu
Disable RX pin
PostPosted: Fri Nov 22, 2013 5:39 am     Reply with quote
Hello forum. How can i disable RX pin ? I have found how to disable TX but not RX .. I`m trying to communicate half-duplex with a 7816 SIM CARD and my tought was to bound the RX/TX togheter and disable/enable them on the fly ..to get rid of echo. I`m running 18f14k50. Thank you very much
PostPosted: Fri Nov 22, 2013 7:43 am     Reply with quote
setup_uart(FALSE);
Disables the UART.
setup_UART(TRUE);
Turns it back on, with the existing baud rate.
pulurumbuluruciu
PostPosted: Fri Nov 22, 2013 12:02 pm     Reply with quote
hah Ttelmah , is no good to disable both TX/RX . how I am gonna transmit if i disable both ?
SherpaDoug
PostPosted: Fri Nov 22, 2013 12:17 pm     Reply with quote
Why do you need to disable the RX pin? It is a Hi-Z input that should not load the TX significantly. Just flush the RX buffer after a TX.
asmboy
PostPosted: Fri Nov 22, 2013 12:26 pm     Reply with quote
if you use #INT_RDA and modify the INT handler , you can use a bit flag
to prevent received chars from being added to the buffer.
simply use the standard CCS functions to read the state of the RX pin.
problem solved
pulurumbuluruciu
PostPosted: Fri Nov 22, 2013 4:09 pm     Reply with quote
Thank you all very much for your inputs. I will make some tests and hopefully chose the best solution.
