Need 2X2 keypad driver
ihsanbu
View user's profile Send private message AIM Address Yahoo Messenger MSN Messenger
how i can use for 2x2 keypad
PostPosted: Fri Nov 22, 2013 11:00 am     Reply with quote
how i can use for 2X2 keypad
UP_Key
Dwn_Key
Entr_key
CNCL_Key
regard
PostPosted: Fri Nov 22, 2013 4:50 pm     Reply with quote
Simply modify the kpd.c example that CCS supplies in the examples folder.
It's very well documented, easy to reduce into a 2by2 kpd.
It might be easier for you to just have 4 switches attached to PortB high nibble,use an ISR,decode which switch was pressed(code for that is in the CCS Help files).
Without knowing which PIC we probably can't help further.
hth
jay
PostPosted: Fri Nov 22, 2013 5:13 pm     Reply with quote
Post a link to the webpage for your keypad.
